Results 1 to 10 of 10
    Jul 2012
    Question Honeywell Vision Pro 8000 Thermostat question
    We have a Trane Heat Pump and need a new thermostat. What is the difference between the Honeywell Vision Pro 8000 Commercial and the regular Vision Pro 8000?
    I want to be able to operate the system manually sometimes and I'm not sure you can have a permanent hold with the commercial version.
    Thanks for the help.
    Quote Originally Posted by felloffthetruck View Post
    Temporarily hold, and bypass for occupied times in schedule
    Jul 2012
    OK, So if I want a permanent hold and to be able to operate the system manually I better go with the non commercial version?
    Thanks.
    Jul 2012
    Anyone know?
    Calgary, Alberta
    Yes. If you have a couple bucks to spend why not move up to the vision pro IAQ or prestige 2.* model?
    Thanks.
    The commercial version(TB8000 series) can be set to non programmable.
    Jul 2012
    Please tell me how? Thanks
    In the installer set up menu you tell it no programs.
    ISU 160 as I recall.
    Jul 2012
    Thanks, beenthere
    So what is the basic difference between the commercial and regular version of this thermostat?
    Commercial can use different resistance remote sensors, also has economizer ability.
