Results 1 to 10 of 10
    Question Honeywell Vision Pro 8000 Thermostat question
    We have a Trane Heat Pump and need a new thermostat. What is the difference between the Honeywell Vision Pro 8000 Commercial and the regular Vision Pro 8000?
    I want to be able to operate the system manually sometimes and I'm not sure you can have a permanent hold with the commercial version.
    Thanks for the help.
    Quote Originally Posted by felloffthetruck View Post
    Temporarily hold, and bypass for occupied times in schedule
    OK, So if I want a permanent hold and to be able to operate the system manually I better go with the non commercial version?
    Thanks.
    Anyone know?
    Calgary, Alberta
    Yes. If you have a couple bucks to spend why not move up to the vision pro IAQ or prestige 2.* model?
    Lancaster PA
    Thanks.
    The commercial version(TB8000 series) can be set to non programmable.
    Please tell me how? Thanks
    Lancaster PA
    In the installer set up menu you tell it no programs.
    ISU 160 as I recall.
    Thanks, beenthere
    So what is the basic difference between the commercial and regular version of this thermostat?
    Lancaster PA
    Commercial can use different resistance remote sensors, also has economizer ability.
