    Fan blower always on
    I recently replaced the varriable speed motor on my 2.5 year old Trane 3 ton home ac/heating unit.
    It had failed because the idiots who installed it didnt connect the ducting correctly and restircted the return air supply down to about 25%, I am actually surprised the motor last the 2 and half years that it did.
    So now the ducting issue has been fixed I can actually hear the air rushing through the vents in the house. So here is my question. Should the blower fan always be on? I can hear it is on even though there is no air flowing, So i am guessing it is just spinning at a slow rate, not enough to blow siginificant air but enough that I can hear it spinning while I am standing under the return air vent.
    In the past with the old restricted air flow set up, when the ac unit shut down, I didnt hear anything at all.
    Also, an additional question, I was told by the ac guy to use the cheapest air filters and just replace them on a monthly basis as apposed to using the more expensive air filters. Is this good idea?
    Thanks in advance...
    Houston,Tx.
    Quote Originally Posted by hrabini View Post
    I hope you warrantied it, because it was still in warranty if it was only 2.5 years old. To answer your question, it could be many things you probably need to call for service.
    Oct 2006
    The Beach
    Call a pro and ask him to fix your unit. The information you are giving us just does not sound right.
    Blue Fox
