Results 1 to 13 of 14
    Apr 2011
    Pennsylvania
    Lightbulb Niagara "web services" client?
    Any tips on implementing a "Web Services" client in Niagara (either R2 or G3)?
    I need to communicate with an electrical utility service via a SOAP/1.1 compliant connection, to poll for command info about our zone.
    They supplied us with a .wsdl file (and .NET code), but I don't know which Niagara module or framework I would base this off of. The Obix stuff is implemented in Web Services, but the utility isn't using Obix.
    Searching Niagara Central only seems to show me ways to implement a Web Services server.
    I could implement this in C#/VB.NET and use OPC to communicate the event with R2/G3, but it would be much cleaner if I could just do it all within Niagara.
    Melbourne
    try GetHTTP from the AxCommunity jar
    1 + 1 = 3 ( *** for very large values of 1)
    ...everybody wants a box of chocolates and long stemmed rose
    Be brave. You cannot get eaten by an imaginary tiger.
    Apr 2011
    Pennsylvania
    Quote Originally Posted by MatrixTransform View Post
    GetHTTP looks like it is just grabbing the source of a requested webpage, and returning it as a string.
    I was really hoping to find some SOAP framework code which could accept the .wsdl file, parse the schema and return the elements that are specified in it.
    San Diego, CA
    Quote Originally Posted by jrevans View Post
    Check with Mike Arnott at Kors Engineering, they have a Web Services server for AX. It uses Java 1.5 libraries, which would prevent you from running this on QNX JACEs with the J9 JVM (J2ME libraries)
    http://70.40.199.119/products/web-se...or-niagara-ax/
    Apr 2011
    Pennsylvania
    Quote Originally Posted by digo View Post
    I read of the Kors module, but it appeared to be for serving Web Services, not consuming Web Services.
    But, in this thread: https://www.niagaraframework.com/ord...ionThread/9276
    he mentions a utility for consuming.
    I suppose I could drop him an email.
    Cost is going to be an issue, since I can develop a .NET / OPC application for free....
    San Diego, CA
    Great, If I ever need an app developed... now I know who to talk to
    Mike started the AxCommunity project on sourceforge, perhaps you can persuade him to include the web services client in the community module.
    Apr 2011
    Pennsylvania
    I can do Modbus/TCP too.
    I'll start out by emailing him first.
    Melbourne
    ...cant you take the String returned or ByteArray or whatever and parse it for XML elements etc etc
    Apr 2011
    Pennsylvania
    Indeed I could, but I was under the impression that when properly using Web Services, the server would only return the requested data elements. (Then again, I've never used Web Services, so I don't know much....)
    I'm supposed to be polling every five seconds, and didn't really want to be grabbing too much data every time.
    Melbourne
    yeah, so you send the appropriate request with a POST/PUT and the server will respond ... and you can pull apart the XML
    Apr 2012
    You could use any generic Java web service library (e.g. JAX-WS 2.0) to build SOAP client for Niagara.
    Apr 2011
    Pennsylvania
    Quote Originally Posted by pault View Post
    Thanks pault. I just looked at the JAX-WS stuff. Interesting.
    My biggest problem is that I've never done Java development for Niagara (and haven't seriously written in Java for ten years....)
    We do have Eclipse setup on our server, and another developer did some stuff with it, so I'll have to take a look at how it is done.
    It appears that we have an error at Eclipse startup which I have to figure out:
    An internal error occurred during: "Loading Niagara Plug-in".
    java.lang.IllegalArgumentException: Attempted to beginRule: MultiRule[P/axCommunity,P/.org.eclipse.jdt.core.external.folders], does not match outer scope rule: com.tridium.niagara.project.rules.NreRule@121bfd6
    Can anyone point me to a good Java / Niagara tutorial?
    Apr 2011
    Pennsylvania
    Niagara / Java development
    I read some stuff over on Niagara Central, and that error was apparently fixed in later versions of the plugin. I upgraded the plugin from 7.1.3 to 7.1.6 and the error went away.
    Now, off to learn how to use this stuff.
Tags for this Thread
