Results 14 to 26 of 46
    Madison, WI/Cape Coral, FL
    Are the fresh air intake and exhaust connected to the furnace via the two plastic pipe? Is there an additional fresh air inlet?
    Regards TB
    Oct 2010
    Good chance your getting the fumes from the water heater drawn into the intake.
    X2
    Oct 2010
    You need to get someone with an accurate CO test instrument to check for ppm (parts per million) of CO in the home. Most co detectors are not sensitive enough to detect dangerous co levels until about 2 seconds before you pass out or never detect it at all
    Sep 2012
    Thanks for the input. The HVAC gentleman is coming back tomorrow. I mentioned that to him the other day, and he informed me that "the fresh air intake is only for the flame and should not matter that it is near the exhaust."
    Brand new house, zero signs of mold. All of our symptoms point to some sort of gas or VOC.
    Thanks again everyone.
    Where is your fresh air connected to.
    Sep 2012
Size:  45.1 KBName:  HPIM2876.jpg
Size:  40.1 KBTeddyBear,
    Yes, the exhaust and fresh air intake are 2 plastice pipes. I will attach a photo. Also, I am attaching a photo of part of our roof. I assume the "white" pipe is our fresh air inlet??? To the right of that are the static dryer vent, exhaust fan and sewer stack,(which they just raised to over 3 feet.)
    Sep 2012
    Here is another image.Name:  HPIM2888.jpg
    Oct 2010
    Everyone should have this type of co detector http://www.climatebydesign.com/co but most have the home depot model that alarms after 70ppm for 4 hours is detected and most of them are installed in a manner that allows "fresh" air to affect them through leaks in wall or receptacle cover and they don't accurately read the ppm in the home
    Ok, the intake is piped directly to the burner. Its not a fresh air intake. its a combustion air intake. And is not able to communicate with the air in your house.
    Sep 2012
    Thanks for the information jtrammel.
    Would a good HVAC professional have something like this as part of their tool-kit?
    Also, do you know roughly how much they cost, and could I just rent one somewhere?
    Sep 2003
    My suggestion is if you don't have your hvac guy check for CO with a proper
    CO detector. Or he doesn't want to do it, or do it properly then I would call your local gas utility or/and your local fire department. They usually don't have a charge for it.
    Explain to them when the gas furnace is running you are getting the following symptoms.... and insist that either one of them check it. Course the fire dept will come arunnin usually with light and sirens
    This needs to be addressed even if it means it isn't CO (Carbon Monoxide)
    Do you have symptoms if you run a floor fan in the living area?
    Sep 2012
    I have run a Hepa air cleaner in the living area and do not have symptoms. It blows air out like a fan.
