Results 27 to 39 of 60
09-19-2012, 04:53 AM #27
I was a York dealer a few years ago, I had bad luck with the condenser coils (commercial equip). Not a good fit for the coastal regions.
09-19-2012, 07:31 AM #28
- Sep 2012
- 16
09-19-2012, 07:54 AM #29
- Jun 2001
- Moore, Oklahoma
- 2,596
I'd go for the heat pump and media filter. The heat pump will cut your winter heating costs in HALF compared to electric heat strips. The media filter will greatly extend the time your a-coil gets dirty/clogged which is the death of many systems. A-coils are labor intensive to get to and are rarely cleaned over the lifetime of a system.
Be sure the ductwork can actually handle 3.5 tons of cooling, if not install a smaller system or fix ductwork. You can only get as much cooling as your duct system will deliver, installing a larger condenser than what your ductwork can handle just wastes power. Ductwork repairs are also labor intensive and rarely get done.
09-19-2012, 08:39 PM #30
- Sep 2012
- 16
Update
I received a quote this evening from another large local company. The salesman was the owner. I always like when owner is involved.
Quoted
18 SEER Trane XL20i 4TTZ0048A100A ,TAM8AOL8V41CA Hyperion air handler with media cabinet ,10kw heat , TCON 900 AC 43UA stat 12 yr parts ... Labor install permits ,
$1000.00 Trane Rebate
______________________________
Total with one yr service and 2 yrs labor
$ for additional 8 yr labor
This gentleman mentioned new building code included
Float Switch safety control
secondary drain pan
Blower door Duct leakage test
load calculation
Plenum modification sealer with mastic ???? He mention they have to pressure test all vent /returns for leaks and any found leaking would cost $ to seal. Is this a scam or normal charge ?
I have 22 vents and don't want to get told I need to seal all of them at additional $ each
Please advise
ThanksLast edited by jpsmith1cm; 09-19-2012 at 09:39 PM. Reason: Removed pricing
09-19-2012, 09:39 PM #31
captgene,
I removed the pricing from your post.
09-19-2012, 10:13 PM #32
- Jun 2001
- Moore, Oklahoma
- 2,596
Why an A/C with strip heat vs. a Heat pump? Your annual energy costs would be lower with a 13 SEER heat pump vs. the 18 SEER A/C with strip heaters.
09-20-2012, 02:30 AM #33
Professional Member*
- Nov 2004
- SW FL
- 5,274
L. O. L. the South is WARM
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
09-20-2012, 07:08 AM #34
- Jun 2001
- Moore, Oklahoma
- 2,596
Wow, never use heat? If that's the case why have the heat strips at all? or do a 5KW heat strips just in case it's cold? But yeah, if it never gets cold a heat pump is in fact useless. Design temp is 44, which is one of the highest in the nation, even higher than many in Florida. Summer is only 92, 4 tons of A/C for 2200sqft sounds like a lot of cooling for a relatively low design temp.
09-20-2012, 08:09 PM #35
- Nov 2004
- SW FL
- 5,274
Know your bin temperatures ( CDDs and HDDs)
Below 45'F about 40 hours a year I believe would be typical [except for January 2010 it was less warm (colder, if you will)]
So, strip heating is used, about a $60 (?) option.
They don't call it the sub-Tropics for nothing.
Guess what _
Typical
___ Wall R-value = 5
___ Glass R-value = 1 (Of course, the limited differential temperature in the summer is < 20).
___ Clear, single pane (or pain) glass is frequently used, so SHGC = 0.88
___________
___ kinda wierd, but Definitely TRUE!
_______
2,200 square feet with SHGC of < 0.5 would typically be ~ 3 tons.
January 2010 might happen once in ~25 years in SW FL.
http://www.wunderground.com/history/...q_statename=NADesigner Dan
09-20-2012, 08:55 PM #36
Blower door tests are always a good thing you don't have to seal the ducts if you don't want to but at least you will know they are there and know where you can improve the efficiency of your hvac system and home. It wouldn't be very smart to put a 20 seer hvac system on a leaky duct system because leaky ducts will lower the actual seer down to considerably. Most homes I've tested the ducts leake from 20-40% of the capacity of the system and loose at least 3 or 4 seer points because of the leaks.
09-20-2012, 09:38 PM #37
- Jun 2001
- Moore, Oklahoma
- 2,596
09-20-2012, 10:18 PM #38
- Nov 2004
- SW FL
- 5,274
Designer Dan
09-21-2012, 05:32 AM #39
- Nov 2004
- SW FL
- 5,274
Biggest driver of high electric bills is t-stat < 76'F.
72'F might increase bills upto ~ 70%.
It's normal for A/C to run constant from noon to 6+ pm for 140+ days a year.
20 A seems more like a 10 SEER 3.5 ton unit than 13, But I don't have the model #s nor the specs for a particular Rheem unit.Designer Dan
