Results 14 to 26 of 29
    Jul 2009
    Columbia, MD
    ABC will disconnect existing air conditioner. ABC will seal off refrigerant tubing and condenser. General Contractor is responsible for storage of unit while disconnected. ABC will re-locate unit to specified location. ABC will extend existing refrigerant tubing to new location and install a LLFD. ABC will perform evacuation and put system back into operation. ABC will give a 30 day warranty on work performed on system. ABC will give no warranty on any other part of equipment. If later repairs are needed they will be billed by T&M.
    Jun 2010
    Thanks Pete! That's exactly what we were looking for! Believe it or not there are people out there having the same issues and thats why hvac talk is good and we need to keep it the same. Its not all about politics and who's the professional. Right? If its an old system and the homeowner wants to do landscaping I agree with you. It needs to be documented and written down. Stupid contractors are quick. Its a remodel world. Thank you.
    Jun 2010
    Thank you Gravity and Pete!
    I'm an Iowa boy with my little boat named Baycienda.
    May 2005
    South
    If you worry enough those six cans of worms will all open on their own.
    May 2012
    NC
    A way to minimize risk would be to take the condenser home after you've disconnected it. I don't know about your insurance but I'm pretty sure mine covers equipment in the truck/van.
    Also, business ownership is a constant balance of risk management and risk vs reward. Business ownership is inherently risky. I ask myself in instances like this, what's the worst that can happen and can I deal with it? Can I afford to return several times if I have bad problems? Does this customer/contractor represent possible future profit on other jobs or is he just using me? If left on site and stolen, can I get a new condenser that matches? If I reconnect it and it craps the bed, does the contractor understand that it may cost serious money? Just some food for thought.
    Turning down work is sometimes the best way to protect your business and reputation. IMHO, what Pete wrote is spot on, if you choose to bid the work.
    VA
    Bay, it's entering the slow season, and we need to collect $$$ when we can.
    I don't think anyone would condemn you for doing this job. We've done it on a few occasions, without issue.
    I do think Pete had a pretty good template for you to use.
    There is risk in any job, but without risk, there is usually little reward. If the GC/Builder that's hiring you likes the way you work, it may prove to be a great working relationship.
    "The only true wisdom is in knowing you know nothing" Socrates
    Visit us at Dr. Degree°s HVAC
    or like us on Facebook
    Quote Originally Posted by alamo1718 View Post
    Don't be a storage company, leave the condenser on the customers property. If it would fail to work 2 weeks after its re-installed, they could claim that you did something to it to make it fail while you had it at your shop.
    Jun 2010
    I agree. Documenting it and getting at least the contractor to review and sign it. Lots of times I don't even know who the homeowner is. Its one of those things where the contractor says just go get it done and you will see the guys working out front.
    There's good money in it. Its pretty much just labor and a few parts and I have to make the contractor happy so he'll keep me busy in the winter. Now watch, what will happen is hvac will slow down and I'll get under bid after putting up with this over the summer and end up losing over the winter.
    I try my hardest to make sure the system is functioning well before I pull it out and do everything I can to make sure it will run well when re-installed. It doesn't bother me if I have to put a new part in because I think its going to fail in a situation like this.
    I don't want to remove the condenser off site like beenthere said, it leads to doubt in the homeowner and contractor. If I write down condenser is the homeowners responsibility after disconnected. The other thing is older condensers don't like to be moved. Its easy for them to get loose and shake. You have to kind of baby them.
    Apr 2006
    Tyler, Tx
    Beautiful! Pete838, love the legalese! hope this isn't copyrighted.....
    Philippians 4:13
    I can do all things in him that strengthen me.
    Apostle Paul inspired by GOD.
    Phoenix,AZ
    This is insane!!!! Unhook the low voltage, high voltage, Cut the lines and braze them shut!!!! What's the problem??????Do you want me to come do it for you? lol
    Apr 2006
    Tyler, Tx
    Quote Originally Posted by KB Cool View Post
    Think the 'problem' is since the unit is ancient he is worried about any liabiblity if it fails after he reinstalls. Hes just trying to cover his a$$ thats all. Worst case compressor fails after a week and then your on the hook for a new unit since you were last one to touch. So the disclaimer clause should keep him out of trouble....
    Philippians 4:13
    Jun 2012
    Amen just add no warranty on the dotted line. Done this a number of times and never had a worry. I do always stress to whoever has the unit to store it safely from vandals since it is so easy to move.
    Aug 2012
    MN
    Last company I worked for did these disconnect reconnects for a landscaping company. Never was an issue. Ended up doing quite a few. We also ran a lot of gaslines for outdoor fireplaces and bbq grills.
