Results 1 to 13 of 14
Thread: Mini-Split Misery
08-20-2012, 07:57 PM #1
- Jun 2011
- MN
- 26
Mini-Split Misery
Without naming the customer, we have several mini splits inside a sugar factory in the Northern part of MN where they grow sugar beets. These mini splits are used to cool electrical control rooms and the "outdoor" unit is generally just out in a hallway and rejects heat out into to the plant. Last week I serviced one of these units and ended up removing the reversing valve and just welded up the correct lines so the thing was permanently on "cool." It ran well for a day and now there is just blinking lights that just say "Craig, beat me with the big hammer and put me out of my misery." UGGHHHHHhhh...how do you troubleshoot these things? I downloaded a cheat sheet and every other option is "new board." Just write it up for a new board and hope for the best???
08-20-2012, 08:00 PM #2
Post make, model number, and flash code and you might get lucky... Nobody can TS it with that info.
08-20-2012, 09:35 PM #3
Depends on the manufacturer.
Fujitsu wants you to talk to them.
Mitsubishi is similar, if I remember correctly, but they're not as hard line as fujitsu.
One thing to keep in mind, if it's an inverter drive, don't try and superheat/subcool. If you think the charges is wrong, dump, and weight in."Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
08-20-2012, 09:56 PM #4
I feel your pain Craig i just installed an off brand now i know why board died next day worked fine for 1 day changed board and has been working good since good luck!
08-21-2012, 10:20 PM #5
- Jan 2012
- 9
Mitsubishi has pretty decent troubleshooting charts to download. Ive worked on alot of those. Depending of the manufacture those things can blink codes for all kinds of reasons so best to just start going thru the charts and narrowing the problem down. Not saying its not a circuit board issue, but with how my luck runs I put on the circuit board and the problem ends up being a sensor!
08-21-2012, 11:34 PM #6
I have never removed a reversing valve but I do know that the inverter Mitsubishi units (PUMY) are sensitive to changes in the refrigeration system. Even hooking up gauges change the compressor frequency. Maybe its pissed off that you removed its reversing valve and its decided to make you cry in your Corn Pops?
-Alfred E Newman
08-22-2012, 04:58 PM #7
These mini-splits are very sophisticated units. They're not your grandfather's system. They're controlling EEV's and the slightest change can drive them bananas. I'd never even consider removing a reversing valve from one. Length of the circuit is changed and any help from the manufacturer probably l went out the door with the old valve. Beats me why you didn't just fix it right. If you've got a load of the same unit, why not put on ball valves and swap out the bad unit a repaired unit in short order? Saves down time, allows for proper repairs in a shop where you've got all the kit and more comfortable facilities too.
08-22-2012, 07:05 PM #8
- May 2010
- Oxford, UK
- 255
You can check thermistors/sensor with a multimeter, just need to know what resistance they should be at a certain temperature (though they can be fine when cold then go faulty when the warm up and vice versa) I have just got myself a resistance decade box so i can mimic sensors that i think are faulty, that way i don't order and fit a new sensor only to find the board is bad too!
Recent thermistor/sensor problem on a Toshiba unit i did,
I have a vid of the decade box on my channel, was about $80.
08-22-2012, 09:37 PM #9
- Dec 2011
- bedford ind
- 1,080
Did you remove the reversing valve control lead? The board logic may be interrupted/out of sync.
09-09-2012, 07:29 AM #10
- Jun 2011
- MN
- 26
I think I was voicing frustration more then asking for help. This place is so bad....sugar in the air clogs up condensers, eats away copper, they have condensers out in 110 degree hallways...they really need a big chiller instead of 25 different conventional AC's for each section.
09-13-2012, 08:20 PM #11
i love mini splits. I do not love working on mini splits however. I have charged a unit based off of performance (DT), without having to dump and recharge. That was on a unit i knew had a small leak. Had lote of service calls and needed to get them cooling. Havent had any problems with it.
09-13-2012, 10:29 PM #12
09-14-2012, 10:59 PM #13
- Sep 2012
- 24
