Results 1 to 4 of 4
    Nov 2005
    Intelipak Remote pot.
    Does anybody know what the ohms value Trane likes for the remote economizer minimum position. I think it is TB-14 terminal 8 and 9, but the 135ohm kele control that is hooked up has no effect on the position. Is is programming or the wrong ohm value? Any advice?
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    i don't believe that there is a TB14...i guessed at one of the 78,474 different model numbers that make up Intellipaks but then I gave up.
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Jun 2006
    New Jersey
    I believe it's 270ohm. Also, you need to set the default OA min position setpoint source to remote pot. It's under setpoints>setpoint source.
    Nov 2005
    I will give it a try. I am tempted to purchase the remote pot from Trane just to see what the ohm value is.
