Page 2 of 6 FirstFirst 123456 LastLast
Results 14 to 26 of 71
Thread: RSES EXAM
    Southeastern Pa
    Not that I know of.
    Why do people say the CM exam is hard? I got an 86 on my first try...
    I kid, the CM test is crazy because of how broad it is, but you only need to get 70% right, so you can completely bomb out on some categories, and still pass.
    When I took it, I didn't get even one single answer right on pneumatic controls or commercial refrigeration evaporators.
    I've failed the heat pump CMS test twice though, once by 2 questions, once by 1 question.
    Most/all of the test questions are taken from the RSES heat pump training manual, and I hadn't studied it, except for brushing up on some some specific things I don't have much experience with, like water source heat pumps.
    Next time I take it, I'll have actually studied the the whole RSES heat pump training manual.
    The "problem" with a lot of tests in the HVAC industry is that the real world answer to a lot of questions can vary by manufacturer, and often specific model, so if you haven't studied the specific source material that the questions were pulled from, your answer could be wrong, even though it is acceptable in real world applications.
    8th grade
    Absolutely not.
    Just take it and cry!!!
    Quote Originally Posted by suBcools View Post
    Does one need to be an RSES member for x amount of time before being allowed to take a test?
    8th grade
    took it today
    just as ridiculously hard as the others!!!!!!!!!!!!!
    i think i did okay??????????
    I WILL SELL WORK,GENERATE BUSINESS, GO GET NEW CUSTOMERS!
    YOU SHUT THE HELL UP AND QUIT RUNNING YOUR MOUTH!
    8th grade
    Woohoo!
    I passed!!!!!
    85
    In a boiler room
    Good job!!!
    8th grade
    Thanx chuck!!!
    8th grade
    Thanks jeremy!
    Did you get the hot chicks furnace fixed?
    8th grade
    What sucks is
    Now 3 of the 4 exams left i suck at!!!
    Commercial refrigeration
    Controls
    Heat pump
    Quote Originally Posted by supertek65 View Post
    Thanks jeremy!
    Nope.
    She still hasn't given me the coupon.
    8th grade
    Its okay Jeremy
    I havent gotten the coupon for a while!!!
    Its okay Jeremy
    I'll just make her wait.
    She'll get cold soon enough...
