Results 1 to 13 of 24
09-13-2012, 03:14 PM #1
- Mar 2006
- 17
Broke older style mercury thermostat - can I get a replacement? Trol-a-temp
Hi,
I have an older Honeywell trol-a-temp thermostat which I managed to break. I am posting images of my items, but can I just replace it with a digital thermostat? If not, can I buy something off of ebay or somewhere else that might work?
Mastertrol Mark V, 2 zones.
If i put two of the wires together, I can get it to turn the heat on, the other two wires will turn the air conditioning on. There are a total of 3 wires for this.
The way the setup works, is I have the master control of heat, fan, or A/C in an office, the thermostats are all set on their own, when i turn on the master control to one of the three selections, the heat/a/c goes on & the thermostat will stop calling when ti gets to the temperature.
Is there some way for me to make this work with a three wire thermostat?
Thanks,
Rich
09-13-2012, 03:41 PM #2
Professional Member*
- Sep 2003
- 1,432
This is not a diy site. I hesitate as to what advice I can give you
For Example......I have no idea what voltages you are working with here.
Maybe call a pro in this instance...Check our map for one in your area.
Did you break the Vessel that held the mercury?
09-13-2012, 03:55 PM #3
- Mar 2006
- 17
Hi,
Sorry I didnt realize this was a DIY question. What happened is during some painting, the old thermostat was removed from the wall & then somehow thrown out. I have the wires sticking out. I called my HVAC guy who said they dont make those thermostats & I should buy a new $ system. I really only want to replace the thermostat until the system does finally die (it is from 1983). I know its on borrowed time, but its a new to me house.
I am guessing the guy was more interested in selling me a huge system vs helping me find a replacement thermostat.
I am not looking for DIY, just more a direction to look to get a replacement thermostat.
EDIT: the guy did say something regarding it had to be a mercury thermostat which sounded wierd to me.
Thanks,
RichLast edited by beenthere; 09-13-2012 at 05:21 PM. Reason: price
09-13-2012, 04:28 PM #4
Since you have a separate changeover control in the system, you can use pretty much any mechanical, or battery powered digital, thermostat in place of either of the zone thermostats.
Any competent tech should be able to figure it out, but some guys don't even try when they see numbered terminals instead of R, Y, W, etc..
There is also a way you can wire and configure some heat pump thermostats to zone 1 that would allow you to eliminate that ugly old changeover control, but you need at least 6 control wires to the zone 1 thermostat location, and at least a basic understanding of how that system operates.If more government is the answer, then it's a really stupid question.
09-13-2012, 05:23 PM #5
White Rodgers has digital stats that work fine with those systems. I'm sur others do too. Some techs just go for the upsale.
09-13-2012, 05:49 PM #6
Yeap!
Pretty much any battery powered digital will work, but White-Rogers is the only brand I know for sure has thermostats that can be used as the Zone 1 thermostat when the system doesn't have a changeover control, or if you want to eliminate an existing one.
With a White-Rodgers single stage heat pump thermostat, that has separate B and O terminals that get powered even when the stat is configured for gas heat, installed as the "zone 1" thermostat, you can eliminate the changeover control.If more government is the answer, then it's a really stupid question.
09-13-2012, 09:18 PM #7
- Mar 2009
- Mount Holly, NC
- 1,626
and that thermostat is NOT mercury. it's an old magnet style. they still sell them at lowes...
The three big summer hearththrobs...
Mel Gibson
Dwane Johnson
The A/C repairman
09-13-2012, 09:45 PM #8
- Jun 2001
- Moore, Oklahoma
- 2,594
I've seen those stats used in mobile homes where the heat/cool switch is on the furnace.
It's a standard "heat only" thermostat.
09-14-2012, 01:13 AM #9
09-14-2012, 07:50 AM #10
- Jun 2001
- Moore, Oklahoma
- 2,594
09-14-2012, 09:24 AM #11
Just looking at the T-stat pictures I thought you needed a new system too, if you have a good relationship with your HVAC guy and you trust him, why wouldn't you trust that your 30 year old system needs replacing? If you don't trust him then call another company, I'll bet they tell you the same thing.
09-14-2012, 02:32 PM #12
- Mar 2006
- 17
I have a brand new relationship with the HVAC guy. Really I would rather find a thermostat that works, give it a year or two & get another system when I am ready.
I was looking on google shopping: Links to direct purchase sites are not permitted.
Would this one should work? I also was looking for the mobile home style ones but I would appreciate any recommendation. Again I am not looking for help installing it, I just want to know which thermostat will work.
On one hand, I have the HVAC guy saying no thermostat in the world will work but one from 1983 vs you guys saying that pretty much any three wire one should work. I am expecting that you guys are correct.
THanks,
RichLast edited by beenthere; 09-14-2012 at 03:29 PM. Reason: removed link to direct purchase site
09-14-2012, 03:24 PM #13
With that ancient panel, can you have your switching on a thermostat? Seems to me no but we haven't had a customer with one of them in many a year. They've all modernized!
