Results 1 to 13 of 14
    Sep 2010
    Mitsubishi Heat Pump down to 0* ?
    I've heard that the Mitsubishi Heat Pumps operate down to 0*. Does anyone know how they make this happen?
    Quote Originally Posted by David Lang View Post
    Physics, there is heat in the air down to absolute zero 460 degrees bellow zero. As long as the refrigerant temperature is bellow the ambient it will be picked up and be rejected inside.
    Sep 2010
    True . . . But doesn't the COP drop off as the temprature drops?
    Portland OR
    Yes but in the end if the COP is higher than 1.0 then its still operating more efficiently than any electric resistance heat. Mitsubishi uses what they call a Hyper Heat module that helps the unit have rated capacity at 5F and work to 0 degrees.
    I assume you are talking about the MSZ-MUZ-FE12 or FE18 models right?
    Check out my YouTube channel - http://www.youtube.com/user/skyheating1 We have customer testimonials, product reviews and more!
    Like us on FACEBOOK if you like our advice here!
    It has an inverter driven variable capacity compressor.
    Several manufacturers inverter drive heat pumps are able to maintain their full heating capacity down to outdoor temperatures in the teens, and still be near full capacity down around 0ºF, because they are able to ramp the compressor and outdoor fan motor speed up to maintain capacity.
    Sep 2010
    Has anyone seen a COP curve for these units that run down to 0* ? I'd like to figure out when gas becomes more cost effective given my rates.
    Aug 2001
    Pavilion, NY
    Saint Joseph, MI
    That doesn't really show COP and full speed. Of course that's the challenge with vairable capacity units. The efficiency will depend on both indoor load and indoor and outdoor conditions. You also have to multiple the frequency correction factor to the heating performance correction factor. But single speed units have a similar problem, because they can take 8-10 minutes to reach steady state rated effciencies. SO a unit that short cycles vs. one wiht long run times can have efficiencies vary by 30%.
    Sort of like EPA fuel economy numbers on passenger vehicles. They can vary dramatically based on driving conditions. I always liked how my BMW motorcycle was rated. It gave steady state fuel consumption numbers for a particular speed. THat seemd like a better way to comparatively gauge economy.
    Sep 2010
    This has a lot of great data. Thank you.
    From the table 7-1.3 it looks like this unit consumes 1.63Kw to produce 25,200Btu/h with an outdoor temperature of 55* and an indoor temperature of 70*. At an outdoor temperature of 5*, the unit uses 0.83Kw to produce 10,300Btu/h.
    So the unit keeps producing heat down to 5*, but the COP drops a little and the output drops by about half. Am I reading this correctly? Is this common across the Mitsubishi line?
    SW FL
    COP of ~ 3.5 near/above 25'F might be an economic balance point without too much drop-off in output.
    Gas $1.0/ therm (100,000 BTU)
    Electric ie., $0.12/ kw-Hr * 100,000/3412 / 3.5 = $1.00 per 100,000 BTU
    35'F
    Heat TPC --- 3,412
    _______ kW ---BTU ---COP
    12,000 0.93 --- 3,173 __ 3.78
    25'F
    0.84 kW
    3412
    2866. BTU
    10200 BTU
    3.56 COP
    Designer Dan
    Massachusetts
    In fact, the Mitsubishi line will operate down to -13°F before being shut off. The system ratings for their HP's are 47°F and 17°F just like all other HP's but certain Hyper Heat models will produce full rated output down to +5°F, with outputs dropping below full capacity at temperatures under +5°F. You should also know that the Hype Heat models operate at full output rating for the first 3-minutes of operation at the beginning of each heat cycle. For this reason, it's important to be sure the unit if properly sized for the room(s) or you could end up with short cycling.
    SW FL
    With the normal refrigerant cycle ...
    http://en.wikipedia.org/wiki/Heat_pump
    No, it's not magic, the output decrease is what one must pay address when selecting a heat pump and back-up in regards to the local environment/weather.
    Generally, the heat transfer balance point will be 32'F +/- ~6'F unless you're willing to signficantly lower your room temperature set point ( ~70'F norm)
    Designer Dan
    Sep 2010
    I've been told that some units produce full output down to 0* or 5* (see below). Is that not correct?
    It seems like it would be pretty tough to pull off because as the COP drops the compresser would need to draw even more to keep the output up.
    The table in the spec sheet indicates a drop. I want to know because if it produces full heat down to 0* (or even 10*) then I wont need backup.
