Results 1 to 13 of 14
    Aug 2012
    hanford ca
    pleat filters how often to change
    how often should pleat filter be changed? seems like airflow is affected within a couple of weeks.
    Jul 2011
    East coast USA
    If you had a Manometer you could check pressure drop, that's the best way. if you feel a difference after two weeks and the filters don't seem dirty and if you can see light threw it, they most likely are still Ok. You may have dirty coils or something else going on. When was the last time you did a Check up?
    Aug 2012
    hanford ca
    the filters do get dirty they do there job but was thinking about adding a electronic cleaner to cut down on pm
    Jul 2011
    East coast USA
    it depends on the air your trying to clean, how dirty is this place.
    what kind of system are we talking about and size of unit?
    Ohio
    Your question is entirily dependent on what sort of atmosphere your filters are used in.
    Sawmill, once a week.
    Medical lab, once a month, if that.
    Aug 2012
    hanford ca
    worm farm lots of sawdust
    Ohio
    Quote Originally Posted by dogheads View Post
    You just answered your own question.
    Funny I said sawmill because that is the worst place I had ever seen for abuse on filters, you came back with worm farm, lot's of sawdust.
    Aug 2012
    hanford ca
    well i knew it was bad but trying to find way to cut down on pm owner dosent seems to think i should have to maint every 2 weeks any input would help
    Rochester NY
    Tell him you could come less, but the repairs are likely to cost more than the maintenance, and be much less convenient.
    Prefilters? And maybe media filters?
    Why can't he change his own filters?
    You'll end up having to clean an electronic air filter/cleaner more often then you change pleated filters now, if your dealing with saw dust.
    Might want to try making a second filter bracket, and install rock catchers in them as pre filters.
    Tallahassee, FL
    Is the return grill deep enough to use a bag filter
    Madison, WI/Cape Coral, FL
    Using a piece of plastic tubing, make a utube mamometer with one end in the duct on each side of the filter. Mark the utube for .1-.2" WG pressure. Dirty filters that are large enough can be very dirty before changing. Double the size of the filter will extend the use time by a factor of +3. Dirty filters are better filters than clean ones.
    Regards TB
    Rochester NY
    ... With the exception being electronic filters.
    Dont the stop working effectively as they get dirty?
