Results 1 to 9 of 9
    Oct 2011
    Austin, TX
    Recommended no rinse evap chemicals
    Anybody use no rinse evap chems? Any particular brand that works the best? Thanks.
    May 2002
    Baton Rouge, Louisiana
    No, If your using no rinse your not doing the job right
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
    Jan 2011
    Boston, MA
    why's no rinse bad?
    Aug 2012
    west burbs,il
    There's nothing wrong with no rinse evap cleaner I use it all the time. However if its really plugged its a waste of time and money, i mostly use on the fairly clean coils during routine maintenance. Or in the cases when you have no choice due to accessibility of cool coil I'll use cans and can n a lot of patience. Anyway go to grainger supply or united refrigeration both work the same.
    Aug 2012
    west burbs,il
    I can't remember names but both houses have only one option.
    May 2002
    Quote Originally Posted by canusayinsanity View Post
    Really? I haven't see a brand of no rinse that doesn't eat the coils up yet
    Aug 2012
    west burbs,il
    I'm talking about the spray foam in can, if that's what u use and its eating coils your doing something wrong. Technically its not entirely true about be a no rinse formula because the condesate running of cooling coil rinses off cleaner, if your using during heating season I'd say maybe you are having troubles with it, there's no condensate- same goes for any no rinse liquid solution you may be using. No rinse can really only be used during cooling season. I'very been using this stuff for a long time with long running clients -same old units and no coil break downs.
    May 2002
    Yep same stuff, we even have a company policy now that it can't be used.
    Didn't realize it was no rinse because the condensate washes it off
    British Columbia, Canada
    Evap-Green no rinse coil cleaner.
    Gallon jug, mix with water 4:1 if memory serves.
    Does NOT eat coils. Works fantastic. Used for the last four years.
    If humidity is low, I'll rinse with water but usually just fire and forget with the pump up applicator.
