Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 44
  1. #27
    Sep 2012
    I am in reading pa can i call you?
  2. #28
    Oct 2011
    Chicagoland Area
    You said it's pumping down but failed to say what the low pressure control is set at.
  3. #29
    Sep 2012
    is that why just the top of the evaporator is frosting?
  4. #30
    Mar 2009
    Mid-Mo
    If jp had a dollar for every time he's linked that sporlan headmaster charging document.....you'd be able to retire!
    On a more serious note, sounds like its time for you to put your cold weather gear on and take some superheat readings after topping the charge off....
  5. #31
    Sep 2012
    you are right!!!! jp is pretty smart good guy to have on our side
  6. #32
    Sep 2012
    that is probably why only the top of evap has a frost pattern
  7. #33
    Mar 2009
    Mid-Mo
    I've learned probably more from him than any of the guys I work with, honestly. 2sac, icemeister, phase loss, and cracker too just to an,e a few more who are awesome.
  8. #34
    Sep 2012
    so tell me undercharged system would cause frost pattern only on the top of evap right
  9. #35
    Thanks, guys. You're making me blush.
    gcmechanical,
    I'll answer any question that you've got here on the forums.
    Yes, low charge will cause uneven frost patterns as well.
  10. #36
    Sep 2012
    jp i really thank you i appriciate your expertise and feel confident that this is the issue good night
  11. #37
    Sep 2012
    i will send you the out come friday
  12. #38
    Quote Originally Posted by gcmechanical View Post
    Thanks.
    Now, 2sac makes a good point, too.
    Take a few extra minutes and verify the settings of all of the operating controls.
    http://www.heatcraftrpd.com/products...%5CH-IM-CU.pdf
    There's another good document for ya.
  13. #39
    Mar 2009
    Mid-Mo
    I took that to mean that it was shutting down on low pressure jp.
    2sac always makes good points, how could you go wrong with a guy who has Al Bundy as an avatar??? That makes me laugh every time I see it.
