Results 1 to 7 of 7
09-12-2012, 10:25 AM #1
- Sep 2010
- Livingston, Montana
- 14
General guidelines for water-cooled A/C and heat pumps
Can someone give me some general tips for setting water reg valves on water cooled units? Specifically, what sort of delta T are we looking for? What sort of condensing temps/pressures? My incoming water temps to the condenser are very low, being fed from a building chiller. So, we're running around 48 degrees! The unit in question was originally on city water, which was around 55-60 degrees. I find my evap is freezing now, and I have to adjust the reg valve accordingly to bring up my leaving water temps and head pressure.
Is there a general rule of thumb you can give me for setting reg valves?
It's R-22 system, btw.
09-12-2012, 11:42 AM #2
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,514
I would think you would want to set your valve for 200-225 discharge pressure. DeltaT is all going to depend on the valve opening up so it's irrelevant .
Wow 48 degree condenser water is cold if you ask me , how's your airflow?
09-12-2012, 12:46 PM #3
Would you expect an air cooled condenser to run properly on a 48* ambient day?
09-12-2012, 01:23 PM #4
What Dallas said.
09-12-2012, 04:54 PM #5
- Sep 2010
- 14
5 ton air handler on 5 ton semi hermetic compressor. Haven't checked airflow, but of course, all this was designed by the building engineer.
I agree thoroughly...48 degrees is mighty cold incoming water. I think there has been a lot of undersight by engineering. Might be looking at corrective options, like hot gas bypass, etc... I don't see this working as it stands.
09-12-2012, 05:31 PM #6
- Sep 2012
- Central Florida
- 687
09-12-2012, 06:56 PM #7
- Sep 2010
- 14
Straight A/C, thank goodness. Adequate insulation. Reg valve is cranked down pretty hard...I guess we watch and see.
