Results 1 to 8 of 8
    Dec 2008
    Buffalo NY
    Confused Trane condensor fan loseing power for a brief second
    Was performing a PM on a new client with two Trane split systems. 410A
    Model# 4TTA3060A30000BB 208 3ph
    Serial # 110751R15F
    When I was checking the condensers, I notice the fan motors would lose power for a brief second. I noticed they both had the factory low ambient kits on them. Part # BAYLOAM103. It was about 70 degrees out so I would think that they should not be cycling at all. There was no literature with the unit so I could not diagnose the problem. When I disconnected the OAT sensor on each unit they both stopped doing it and ran fine. The green led on the board seemed to flash odd also without a steady heartbeat when the fans would lose power. I did not have time to check the charge but that was my first thought that they may be low on refrigerant. I also noticed a red LED flashing but again I had nothing to tell me what it was. If anyone can get me the info or has experience with this type of low ambient that would be great. Thanks in advance.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Virginia
    Quote Originally Posted by qwerty hvac View Post
    Check your email. I sent you some info on this low ambient kit. Can't post technical data in this "OPEN" forum.
    I didn't read the instructions, but I think these kits do start cycling the fan at about 70ºf.
    Dec 2008
    Buffalo NY
    Thanks. I will check it out. Should have posted in the pro section.
    Sent from my iPad using Tapatalk HD
    Dec 2008
    Buffalo NY
    I wonder if they wired it wrong. It says if the Orange is not wired correctly it will not work right. Also the red light was flashing on both boards. I would not think both units have bad low ambient controls. They are less then a year old.
    Virginia
    That easily could be.
    I briefly looked over the manual and it looks like you can test it to see if it is operating properly.
    Dec 2008
    Buffalo NY
    I did hit the test button and it did cycle on and off but the red led was flashing. I will have to check this out before it gets colder.
    Virginia
    As you probably noticed in the manual, Flashing RED is a fault in one of the two sensors.
    Dec 2008
    Buffalo NY
    Quote Originally Posted by rundawg View Post
    Yes I did see that. That is where I am going to start. When I removed the ambient sensor the control stopped cycling the fan.
