Results 1 to 13 of 13
    Apr 2011
    Orlando FL
    Trane XL20i 4TTZ0048B1
    Does someone have access to the Cooling Performance Data Sheet for the Trane XL20i 4TTZ0048B1 condenser they wouldn't mind posting for me?
    Many thanks!!
    Sharon
    Apr 2011
    Orlando FL
    Also, what would be the difference between the 4TTZ0048B and 4TTZ0048A?
    Thanks again!
    Sharon
    Arizona
    Tied to any particular coil?
    Apr 2011
    Orlando FL
    Does 4TXCC008CC3HCA work? I'm particularly looking for the data that shows the sensible capacity as a function of dry bulb and wet bulb temperatures.
    Arizona
    Give me a few and I'll check
    Arizona
    Here ya go, furnace also matters.4TTZ0048B1.pdf
    Apr 2011
    Orlando FL
    My contractor has this furnace specified: TUD2C080A9V4. Does that change the cooling data?
    Arizona
    Yup. Give me a minute or two
    Apr 2011
    Orlando FL
    And, Jim, if you have an extra minute, do you know why the Trane website (for home owners) would specify the condenser as 4TTZ0048A? Rather than 48B? Thx!
    Arizona
    Quote Originally Posted by SharonG View Post
    Here ya go.4TTZ0048B1-1.pdf
    Arizona
    The A model would be the OLDER model. I don't know off hand what the upgrade is in the B model, it could be something as simple as condenser fan blade change. But would be considered a major upgrade.
    I looked at the parts breakdown of the A & B models and can't find a major component different. Same comps, coil, fan motor & blade between the 2. But something as simple as a fan blade change could be the difference though not in this case.
    Apr 2011
    Orlando FL
    Many thanks guys! I truly appreciate it!
    Sharon
