    Feb 2012
    EXV forced closure?
    I recently noticed that my air handler / indoor coil has a pair
    of dry-contact input terminals to force its EXV to CLOSED during
    cooling mode.
    When/why would you want to do this, and/or why would such a
    function want to be able to be externally automated? I can't
    imagine how it could be good for the rest of the system.
    tnx
    _H*
    Fort Worth, TX
    What indicates that this is what the set of dry contacts are for? Dry contacts are often for alarm triggering purposes.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Mar 2009
    Mid-Mo
    Hobbit it this on your Daikin system we have talked about before?
    Feb 2012
    Yup, the Daikin FTQ type air handler. Quoting from the
    install manual description for option block terminals 9,10:
    "Receives input: Forced closure of indoor unit Electronic
    Expansion Valve during cooling operation. (dry contact)"
    Seems like a strange thing to want an input for. Note: this
    isn't the same as "forced off" that you'd use for safety
    switches, condensate-pump overflows, etc.
    _H*
    Sep 2012
    Sorries did not notice this was in the ask a pro section.
