Results 14 to 15 of 15
    Sep 2012
    oops overhaul of the entire HVAC system.
    Rochester NY
    Yeah, that makes for a tough spot. An example of why people should NEVER buy straight AC.
    Unfortunately very few sales people are willing or able to explain why you might want to spend a few bucks more for a heat pump (one valve and an accumulator are the basic difference).
    Your house is so small you could go with an "electric furnace", then when the outdoor unit goes your all set for a heat pump. Probably be cheaper than a new low efficiency gas furnace, and the monthly meter fee savings would likely be more than the increased cost of energy source.
