Results 14 to 26 of 33
Thread: BO AND AO
    edit: but its too late ot go to the supply houe, and you need ot make it work NOW
    Ohio
    Quote Originally Posted by Elfshadow View Post
    Which is why I asked before starting to list stuff.
    Thanks Elf, you get 10 internets points.
    Flange -10 internets.
    Ohio
    Quote Originally Posted by flange View Post
    ok, well he still needs to learn some things. how do you deal with having a 2-10 volt sensor, but need a 4-20ma input??
    Ohhh.. I get to learn something.
    Standing by for ML to respond.
    whuch us better, floating or modulating control, and why?
    Which is better location of a three way valve at a coil, supply or return piping? why?
    May 2002
    Baton Rouge, Louisiana
    Now this I would love to see the answers from the guys here, I've heard both ways with backing arguements for each.
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
    Mar 2011
    Long Beach, CA
    LOL, while you guys are at it, how about a discrete signal.
    Troubleshooting is not part of the repair............understand the symptoms and you will find a solution.
    i am not allowed to answer, i have been scolded once today.....but turn me on for a defined period of time and maybe i will, especially if you do so with intrinsically isolated relays.
    Mar 2011
    Long Beach, CA
    Does using manufactures guidelines qualify as an answer?
    Mar 2011
    Long Beach, CA
    Subliminal, but I get it.
    Melbourne
    Quote Originally Posted by joey791 View Post
    For hot water...
    1- lower pressure of the coil after a control valve may cause conditions where fluid quality to goes down. ie vapour may form in the coil (noise, cavitation, oxygen)
    2- the valve and actuator of a valve in the supply line will be much hotter than the return line (hot actuator = bad)
    3- supply line means more chance of destructive cavitation at higher vapour pressures.
    For cold water...
    1- the supply line may well be below the local dew-point which would mean the valve and actuator may form condensate (water in actuator's moving parts = bad)
    dew point of 22°C @ 50% is 11°C (return may be like 12 °C, and flow may be like 7°C)
    ...bunch of good reasons there
    1 + 1 = 3 ( *** for very large values of 1)
    ...everybody wants a box of chocolates and long stemmed rose
    Be brave. You cannot get eaten by an imaginary tiger.
    Melbourne
    Quote Originally Posted by milkyway View Post
    What is the difference between binary outputs and analog outputs?
    ...spelt differently
    Mar 2011
    Long Beach, CA
    What do you mean? Are you saying they are the same? I am just asking to clarify.
