Results 1 to 13 of 33
Thread: BO AND AO
    Not in Iran
    BO AND AO
    What is the difference between binary outputs and analog outputs?
    Binary is on and off I am thinking,
    Analog outputs is the same but it is more like for a drive?
    I'm doing some reading and was wondering.
    Also binary and analog variables?
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    May 2002
    Baton Rouge, Louisiana
    binary is on/off
    analog-varies, usually a signal that modifies voltage or ma based on settings
    Dad's Hideout The online mancave for dads
    Near Philly
    Really? Please don't tell me you are actually billing somebody for your time.
    Not in Iran
    Quote Originally Posted by mechdorn View Post
    Nope, just like my post said, doing some reading,. What makes u think I am billing for my time??
    Pay attention
    Aug 2012
    Silver Creek, Ny
    I was interviewing for a local DDC control company here in Buffalo, I didn't have any prior DDC experience but I am versed in HVAC and telecom so I gave it a try!
    so I found online a DDC tutorial site that pretty much gives a grass roots explaination of DDC and networks all the way up through BACnet and LON.
    Check it out...
    http://www.ddc-online.org/Digital-Co...l-Systems.html
    BTW...I didn't get the job
    Perfect Practice Makes Perfect
    Desert Southwest
    A commonly used analog output signal is 4-20 milli amps or 0-10VDC with the lower end of the signal being scaled as 0% and the upper end as 100% of the signal.
    A common use is a signal going to a variable frequency drive to an electric motor.
    If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
    No good deed goes unpunished.
    If you want to take off friday to go fishing then make sure you train your helper right.
    Columbus Ohio
    Binary Output (AKA: Digital) is simply on or off. Example: A control board telling a relay to turn on a fan motor.
    Analog output is a variable signal used as a control signal. Example: 0-10vdc from a control board used to tell a VFD how fast or slow to drive a motor. 0vdc = 0Hz, 5vdc = 30Hz, 10vdc = 60Hz, or anything in between.
    Now I want you to study up and give me examples of what a BINARY INPUT and a ANALOG INPUT could be used for.
    UA LU189
    10mm, because it's better than .45acp
    Sep 2012
    Central Florida
    Quote Originally Posted by zw17 View Post
    Can anyone answer??
    Binary input typically used for status. typical bo's include airflow switch, safety devices, relay aux contacts. fan proof=binary input closed, ie airflow switch closed.
    analog input is a control variable, could be an output off of a tempereature sensor, humidity snesor, airflow station, and other controls that give a variable response. example--an airflow station on an air handler delivering a 4-20ma output based upon differential pressure across the fan inlet cone.
    Columbus Ohio
    Flange!!!!
    I wanted him to answer so he could learn something ya dolt!
    UA LU189
    Sep 2012
    Central Florida
    Flange!!!!
    Which is why I asked before starting to list stuff.
    ooppsie, thought we were doing training. my bad for sure.
    ok, well he still needs to learn some things. how do you deal with having a 2-10 volt sensor, but need a 4-20ma input??
