Results 1 to 8 of 8
    Oct 2010
    How to clean lime, calcium build up inside water lines
    Im working on a bard water to air geo thermal unit. It has alot of lime an calcium build up inside the water lines. Its restricting the valves. Is their a way to clean those lines out? any help would be great
    Feb 2012
    North Plainfield ,NJ
    I use t.p.s. cleaner for boilers.
    Sent from my DROID RAZR using Tapatalk 2
    Oct 2010
    thanx for reply... im new at working on geo thermal, been doing everything but it. i herd you can hook up a pump to run cleaner through the water lines. and what is t.p.s.?
    Apr 2012
    Georgetown Delaware
    Typo alert. t.p.s. were the reports that they did in the movie "office space" with the red stapler. lol
    t.s.p. is tetra sodium phosphate commonly used for cleaning all sorts of things. Mechanics in my O.A. seem to like useing those kits for tankless water heaters as a first responder to the fouling of the hx coil.
    Now give me back my red stapler!
    Eric
    Eric Sackett
    weberwelldrilling.com
    Delta P= 8 ATA
    www.youtube.com/weberwelldrilling
    Mar 2006
    Kingston , Ontario
    Thats whats I use to clean coils (tankless pump) but somthing with a little more flow would be better IMO, and depending on water pipes (domestic or source) I will somtimes use just vinegar.
    May 2005
    When I was running open loop, my lines clogged up severely after a few years. I had to use Muriatic Acid to clean them out.
    Apr 2012
    Georgetown Delaware
    The danger with muriatic acid is that it disolves alot of things. One of which was the solvent welds on schedule 40 pvc. I hope to never repeat that nightmare! When looking for a solution to fouling it is better to "wade into the pool" with the least caustic first, rather than " nuke it" right out of the gate. IMHO
    Eric
    Eric Sackett
    Delta P= 8 ATA
    Mar 2006
    Kingston , Ontario
    Ice machine descaler works and no glue on any fittings. All fused or barbed and clamped!
