Results 1 to 7 of 7
    May 2002
    Baton Rouge, Louisiana
    Confused Jace 403 Serial to Ethernet Convertor
    Don't feel like making one and could have used one yesterday, anyone have one they can recommend premade for serial shell access from somewhere like B&B or such?
    TIA
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
    Hampton Roads, Virginia
    I made my own, but I believe this is the one you need,
    http://www.cablesandkits.com/cisco-d...8301-p-30.html
    Kevin
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    May 2002
    Quote Originally Posted by klrogers View Post
    Kevin
    Thanks Kevin, ended up picking up 4 new ones off of Ebay for 12 bucks
    San Diego, CA
    Kevin is right, the cisco null modem cable works. That's the light blue satin that comes with older style cisco routers.
    A JACE and a PC are both DTE devices, and thus require a null modem adapter.
    The pinout between the JACE and the cisco cable is slighly different (DTR/RTS and CTS/DSR swapped), but it does work . As per Dan Anderson @ Tridium, the JACE does not care about the inbound handshake lines on a serial integration. See the difference in pinout below:
    JACE 4/5/XPR series
    null modem cable (Tridium part # 10148)
    RJ-45 /DB9
    1 DTR /6 DSR
    2 RTS /8 CTS
    3 TXD /2 RXD
    4 GND /5 GND
    5 GND /1 DCD
    6 RXD /3 TXD
    7 CTS /7 RTS
    8 DSR /4 DTR
    Cisco null modem (Cisco part # 72-3383-01 or CAB-CONSOLE)
    RJ-45 /DB9
    1 RTS /8 CTS (request to send/clear to send)
    2 DTR /6 DSR (data terminal ready/ data set ready)
    3 TXD /2 RXD (transmit/receive)
    4 GND /5 GND
    5 GND /1 DCD
    6 RXD /3 TXD (receive/transmit)
    7 DSR /4 DTR (data set ready/ data terminal ready)
    8 CTS /7 RTS (clear to send/request to send
    This is as cheap as I've been able to find them:
    http://www.routerswholesale.com/inde...&products_id=6
    May 2002
    Quote Originally Posted by digo View Post
    JACE 4/5/XPR series
    RJ-45 /DB9
    1 DTR /6 DSR
    2 RTS /8 CTS
    3 TXD /2 RXD
    4 GND /5 GND
    5 GND /1 DCD
    6 RXD /3 TXD
    7 CTS /7 RTS
    8 DSR /4 DTR
    RJ-45 /DB9
    4 GND /5 GND
    5 GND /1 DCD
    Thanks for the pinout digo, now all I need is to find some Echelon 70110 cables
    San Diego, CA
    Quote Originally Posted by joey791 View Post
    Do you mean 70010?
    16AWG, 1 conductor, stranded?
    May 2002
    Sorry meant the 75110, got one ordered yesterday-Honeywell badged one
