Results 1 to 9 of 9
Thread: Temp pressure chart error
09-09-2012, 09:43 AM #1
- Apr 2008
- Tucson, AZ
- 59
I found my discharge air colder than my coil! 407A at 18# = -6*f on the Sporlan pocket chart. I found it wrong on some of the iPad apps also from bittzer and danfoss. Oops. I'm sure they will be corrected soon. The Johnstone app seems to have it right.
09-09-2012, 11:27 PM #2
You're looking at the dew point chart, for the evaporator temperature, use the bubble point chart.
Use dew point when the refrigerant is changing from a vapor to a liquid, bubble point when it is changing from a liquid to a vapor.
With R407A, 18 psig suction pressure gives a saturated temperature of -16.6ºF in the evaporator.If more government is the answer, then it's a really stupid question.
09-09-2012, 11:47 PM #3
- May 2004
- 1,732
I've always been taught to use the dew point when determining evaporator superheat.
09-10-2012, 09:35 AM #4
Bubble point is for Subcooling (BUB = SUB)
Dewpoint is for checking superheat.
09-11-2012, 12:55 AM #5
09-11-2012, 06:41 AM #6
Another thing that I'm finding with 407a, and icemeister explained it to me somewhere on these forums and I've found his explanation to be accurate.
The evaporator will change in temp as the refrigerant goes through it.
The inlet side of the evap will be at (or near) bubble point and the outlet will be at (or near) dew point.
When trying to determine evap temperature, particularly for purposes of setting pressure controls used to control temperature and EPR valves, using an average of DP/BP is the best and most accurate method.
09-11-2012, 05:47 PM #7
Here's that thread: http://hvac-talk.com/vbb/showthread....p-small-walkin
Since mccann still isn't a Pro Member...
...I'll post a link to DuPont's article on temperature glide with 400 series refrigerants. It's likely the best explanation available.
DuPont - Temperature Glide With 400 Series Refrigerants
09-11-2012, 08:23 PM #8
- Apr 2008
- Tucson, AZ
- 59
09-11-2012, 08:38 PM #9
