Page 1 of 4 1234 LastLast
Results 1 to 13 of 42
    Feb 2007
    Central NJ
    3 phase scroll rotation
    had and issue with two twinned daikin vrv heat pumps this week where i was getting a "U1" code which indicated incorrect phase rotation. bought a 3 phase rotation meter and i'm going back monday to check the systems. do most scroll manufacturers compressors run cw, ccw or does it vary depending on the maker of the compressor? thanks.
    You have to pay your due's before you pay the rent!
    May 2011
    New Jersey, maybe you are aware of something I have never been taught but when legs on compressor are switched how do you see direction change? I understand with a fan motor and have had to switch legs for correct scroll operation but how do you see rotation of pistons?
    up in the hizzy
    most run clockwise. if the unit has CT/toroids make sure they are installed on the right phase.
    up in the hizzy
    Quote Originally Posted by Iceman7997 View Post
    it wouldnt matter with pistons and there is no way to see it but if the meter helps to identify L1-L2-L3 then all he has to do is land the legs on the right spot.
    May 2011
    (it wouldnt matter with pistons and there is no way to see it but if the meter helps to identify L1-L2-L3 then all he has to do is land the legs on the right spot.)
    What runs clockwise? Basically I was asking a rhetorical question because I have seen the scroll reverse rotation problem. I use my pressures and ears to know if I have to switch legs at contactor. Didn't know about actually have a certain rotation that they call for and how do you tell. Model # or do you have to look it up.
    i have never seen any compressor run CCW?
    but I am sure that there are some!!
    seems like nothing is the same.
    true knowledge exists in knowing that you know nothing.
    Southeastern Pa
    Now you've given me something to do on Monday.
    I'm going to find a running scroll, and take a reading on the terminals with my rotation tester to find out whether the rotation is CW or CCW.
    I'll post back.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    up in the hizzy
    Quote Originally Posted by supertek65 View Post
    I believe in the southern hemisphere they run counterclockwise
    i will bet you a pork tenderloin it is CW!!!!!!!!!!!!!!!!!!!!!!!1
    Quote Originally Posted by timebuilder View Post
    I'll post back.
    and below the 38th parallel??????????????
    Quote Originally Posted by valdelocc View Post
    May 2011
    Hahaha you guys are hilarious. Hey time builder do you think I can borrow your rotation tester cause I think toilet is flushing in reverse rotation but it's possible it was shipped from another parallel. Hahaha
    is it a left handed toilet or a right handed toilet??????????????
    i think syphon jet water closets made above the 38th parallel are actually counter clockwise???
    just sayin????????
    May 2011
    It is left handed from behind the the toilet, and and from what I understand the toilet bowl was made below the 38th and the handle above? Do you think she's gonna make it cause she just recently switched rotation. I haha
