    York YK Centrifugal Chiller
    We have 3 YK series york chillers R134a cooling capacity 1500 Tons.One of the chiller is surging too much condenser Sub cooling is around 10 Deg F.Its motor is 3.3Kv,Ampares are are fluctuating between 70 to 95.Any body can tell what is possible cause.Thanks.
    Somewhere in the world.
    Post all the operating data for the Chiller without it we would all be guessing as to the cause !
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    will you tell me what Data points you required.Thanks.
    Jan 2011
    All the data you would normally take during an operating inspection. Entering and leaving CHW temps, same for condenser, evaporator pressure, discharge pressure, saturated suction, saturated condenser, discharge temp, liquid level in the condenser...you get the idea.
Size:  28.4 KBName:  printer set up.jpg
Size:  39.5 KBName:  printer set up a.jpg
Size:  39.8 KBName:  printer set up b.jpg
Size:  35.6 KBName:  printer set up c.jpg
Size:  30.5 KBName:  York Sales Order.jpg
Size:  41.2 KBName:  History.jpg
    Fort Worth, TX
    What chiller surging basically is: when there is too high of a pressure difference between the condenser and the evaporator for the non-positive displacement compressor to overcome. As a result, gas flow reverses across the impeller wheel, attempting to stall it. This happens in spurts and is why amp draw fluctuates wildly during surging events...the impeller is working against gas flowing in the wrong direction.
    Basic causes:
    Fouled cooling tower
    Fouled tower sump and/or condenser pump strainers
    Fouled condenser tubes
    Failure to lower entering condenser water supply setpoint when chiller load is low
    Charge not trimmed correctly
    Psychrometrics: the very foundation of HVAC. A comfort troubleshooter's best friend.
