Results 14 to 24 of 24
    It sounds like it needs a ptrap
    Rochester NY
    And blower door assisted air sealing of the attic.
    south louisiana
    do you smell it when the hvac is running?
    or all the time?
    still asking...
    Quote Originally Posted by tedkidd View Post
    X2 and ductwork
    Feb 2011
    Quote Originally Posted by energy_rater_La View Post
    or all the time?
    still asking...
    Sorry i missed your question.
    Only when the hvac is running and only when temperature outside start to get really hot, 95 and above.
    Feb 2011
    X2 and ductwork
    Mmhh what is that ?
    Feb 2011
    Ptrap ? Is it dangerous :-)
    south louisiana
    hvac drain has p-trap.
    X2 means that the person who posted it agrees with post above.
    x3 means I agree also.
    ok, so when the unit runs it pulls attic air, temps, dust, and smell of attic into house.
    you need to improve the air barrier between living space and attic.
    when the hvac system runs it pulls air from attic into living space.
    thru ducts that aren't well sealed and any openings between living and
    attic spaces.
    things like recessed lights, hvac supply boxes that aren't sealed where
    the penetrate into living space, stove vents, bath vents, and openings
    around fireplaces are just a few of the areas that leak.
    thus the suggestions for duct testing (to find duct leaks to be sealed)
    and blower door test (to find house leakage to be sealed).
    check with Resnet, BPI for independent rating or audit, by certified
    person who works for you.
    or utilities, who pay in part person who does the testing.
    you will have to keep track of leakage sites, of ducts
    and house, and request duct testing in most areas.
    fyi independents can lead you to higher savings, whereas utility
    companies have a limit as to how much they want to reduce
    their profit.
    best of luck
    Rochester NY
    Let's dig into that last bit. Is that hypothesis, or something you know for certain?
    Is it not wanting deep savings, or lack of vision, or "low hanging fruit/prescriptive measures" mentality that doesn't recognize the cost of getting in the door, and once in putting no value on the missed opportunity to be comprehensive, or some other issue not mentioned?
    God, I'd love to know the answer.
    south louisiana
    last part about utility companies?
    sadly it is something I know.
    I'd rather not get into it in this thread, but
    if you'd like to discuss it more, start a new
    thread in a more appropriate forum.
    just pm me where you want to discuss this.
    or we can just pm.
    Rochester NY
    I was hoping it was ignorance or incompetence. Intentional is going to be much more difficult to combat. How can these guys consider themselves patriotic citizens, harm to fellow Americans and impediment to energy independence could be considered willful.
    Lets start a thread on the building science forum.
