Results 1 to 13 of 24
    Feb 2011
    Confused In my living room i smell attic
    In my living room i have the same smell i have in my attic, i dunno why, any idea or suggestion ???
    Thank you.
    Jan 2005
    Emerald Coast
    Is your ductwork located in the attic?
    Do not attempt vast projects with
    half vast experience and ideas.
    Feb 2012
    Lynn, Mass
    Quote Originally Posted by mstx View Post
    Thank you.
    ONLY in living room?
    south louisiana
    all the time, or when the hvac system is running?
    Fort Worth, TX
    Can also be a sign of reverse stack effect, where attic air is pushed into the house through air leaks in the ceiling.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Oct 2010
    If your return air duct is in the living room and you are closing any doors that have supply vents with no returns in the rooms it will create a negative pressure in the living room that will suck in attic air through leaks in the attic floor, like shophound stated
    Feb 2011
    Wow a lot of answers thank you everybody.
    So let me explain better i smell attic nearby the return in the living room, my duct work are located in the attic, and so the filter, i have just purchased this house and the old AC didn' t pass the inspection so i got a new one for free. I believe is a leak but i dunno where it can be. bedrooms are ok i also have a return in the master and one in the hallway by the guest bedroom.
    south louisiana
    so..you smell it all the time or when the hvac system is running?
    do you have recessed lights?
    return in in ceiling or low on wall with return air chase?
    (where do you change filter ceiling or wall?)
    best of luck.
    Jan 2005
    Emerald Coast
    Does the attic smell like the living room? Just couldn't resist.
    Seriously though, a pressurized attic or depressurized living room. Leaky ducts.
    Quote Originally Posted by Shophound View Post
    or this.
    Feb 2011
    It could be that the furnace is suching air from the plenum ?
    There are some holes like the one for the gas line, it seems to me that is sucking air also from there
    Mar 2009
    Mount Holly, NC
    yes.
    the return ductwork and the supply (cold air vents) ductwork need to be totally sealed, if you got the system for free, it's possible the company that installed it was a low bidder and they did a SUBSTANDARD job on the install. did the system get a ductwork inspection? was there a permit pulled for the job?
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    May 2008
    Missouri
    Sounds like you've got a leaking duct system. Get a good light and start looking, you'll find it. Start where the ducts connect to the return where you smell the "attic" odor.
    Feb 2011
    The condensate start to come out from the drain pipe only when the indoor fan stop. Geez
