Results 1 to 13 of 16
    May 2012
    Upper Michigan
    Triangle tube challenger
    Here is the start of my challenger job, first time installing one.
    Before
    Click image for larger version.
    After
    With cover
    May 2012
    Upper Michigan
    **** wrong place lol now how do I change it?
    Jun 2012
    San Francisco Bay Area
    No idea but clean install
    May 2012
    Upper Michigan
    I guess if it never gets moved to wall of fame thats my sign to quit lol, thanks guy
    Cincinnati, Oh
    Looks nice and clean.
    Before you finish though, is it still possible to increase the distance of straight pipe going into your air seperator.
    Those models need about 18" of straight pipe for laminar flow, so the air seperates from the water, and allows the scoop to "scoop" it up.
    "Just get it done son."
    Dad adjusted
    May 2012
    Upper Michigan
    Quote Originally Posted by hvacvegas View Post
    Lol I know but it's all cast iron rads so in reality it don't even need one, otherwise I would have been more concerned.
    Jun 2009
    Ontario, Canada
    if thats WOS for you I wonder how good is your WOF install???
    Parts Changer Extraordinaire
    Have tools and gauges. Will travel.
    Madison, Wisconsin
    Are you sure your "T" fittings are spaced close enough together? Is that a secondary LWCO at the top of the boiler loop? If so why? Looks clean, get one of the mods to move it to WOP
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Feb 2012
    Toronto Canada
    Clean install
    Post should be in WOP section.
    May 2012
    Upper Michigan
    Quote Originally Posted by Wheelbaron View Post
    The tees have to be a maximum of "12 apart, our inspector still requires a LWCO even though it has one internally. I think I will msg a mod, thought they would have done it by now lol.
    May 2012
    Upper Michigan
    Jp please held I can't send a MSG for some reason but can you move this to walk of fame
    Gotcha.
    Moved to wall of pride
    May 2012
    Upper Michigan
    Gotcha.
