Results 1 to 13 of 19
    Jun 2009
    Upstate SC
    HVAC Load-Calc app by Powertrade
    I just downloaded this app from the Android Marketplace. I've done a load calculation already and it took a little getting used to on adding loads. Commercial Calc for the desktop was much easier, but I do like the addition of partition walls on this app.
    Do any of you that have used it have any tips?
    Mar 2012
    West Chester, PA
    I used it and it came out to be close to the same load calc I did in wrightsoft. So it's not bad. It's just a pain in the a$$ to use on a little phone. I guess it could be cool on a tablet but I would just get the wrightsoft mobile consultant.
    Apr 2011
    Cayuga, In
    is this app hvac buddy load calc. I was searching for it.
    Sep 2009
    Marietta, GA
    Quote Originally Posted by shaworth1 View Post
    I gotta try this out. Is "HVAC Load-Calc app by Powertrade" the exact name?
    Feb 2012
    Lynn, Mass
    If you have a laptop you can download "bluestacks" it is a program that lets you download android apps and use them on your computer... not sure if this helps anybody, but it is available....
    May 2012
    Upper Michigan
    How much is it?
    Sep 2009
    Marietta, GA
    That's a good idea. I am going to try it out. I was about to go get a tablet to run that app. But let me try bluestacks first.
    Jun 2009
    Upstate SC
    Yes its the hvac load -calc by power trade. It was 39.99
    Sent from my ERIS using Tapatalk 2
    Sep 2009
    Marietta, GA
    Quote Originally Posted by jdblack View Post
    I haven't gotten the program yet. But let me ask you something. After you do a load calculation, can it be printed out? How detail of information does this give? Will it give also the cfm required for each room or area?
    thanks
    Jun 2009
    Upstate SC
    Quote Originally Posted by mofotech View Post
    thanks
    You can email the report and then it can be printed out. It has graphs also. If you do a room calc it does give the cfm per room. I have a block calc done. I will try and upload here.
    Sep 2009
    S.C.
    Looking for more info (too). I hate to drop $40.00 on it if its junk. Printing is Necessary!
    Anyone?
    Thanks JD. Your post showed while I was pecking!
    Looking closer, it looks pretty good and all the ratings are excellent.
    I have a Vizio Tablet that's Android.
    Yes, I know I Shouldn't But I Just Can't Help Myself...
    Jun 2009
    Upstate SC
    ============================== ============ Cooling Load : 30,600 Btuh Cooling Load tons : 2.5499875373362264 Latent Cooling Load : 2,611 Btuh Sensible Cooling Load : 27,989 Btuh Sensible Heat Ratio : 0.91 Airflow : 1339 cfm CFM/Ton : 525.2
    Cooling Temp Diff : 19 °F Cooling Volume : 10,935 ft³ Floor Cooling Area : 1,215 ft² Latent Cooling Duct Load : 0 Btuh Latent Cooling Infiltration Load : 2,011 Btuh Latent Cooling Ventilation Load : 0 Btuh Sensible Cooling Duct Load : 0 Btuh Sensible Infiltration Cooling Load : 1,818 Btuh Sensible Ventilation Cooling Load : 0 Btuh Heating Load : 44,627 Btuh Heating Load tons : 3.718887744762697 Heating Temp Diff : 48 °F Heating Volume : 10,935 ft³ Floor Heating Area : 1,215 ft² Heating Duct Load : 0 Btuh Heating Infiltration Load : 10,869 Btuh Heating Ventilation Load : 0 Btuh
    Project Loads ============================== ============ Above Grade Wall, North, North wall kitchen heating 1,106 Btuh, cooling 726 Btuh (2) Windows, [North], North window kitchen heating 1,411 Btuh, cooling 780 Btuh Above Grade Wall, East, East wall heating 1,131 Btuh, cooling 417 Btuh (3) Windows, [East], East window heating 2,117 Btuh, cooling 2,745 Btuh Above Grade Wall, South, South wall heating 964 Btuh, cooling 355 Btuh Window, [South], South window heating 706 Btuh, cooling 525 Btuh Wood/Metal Door, South door heating 393 Btuh, cooling 254 Btuh Above Grade Wall, West, West wall heating 1,062 Btuh, cooling 250 Btuh (4) Windows, [West], West window heating 2,822 Btuh, cooling 3,660 Btuh Above Grade Wall, South, South wall Copy heating 1,020 Btuh, cooling 376 Btuh (2) Windows, [South], South window Copy heating 1,129 Btuh, cooling 840 Btuh Above Grade Wall, East, East wall Copy heating 1,718 Btuh, cooling 634 Btuh (3) Windows, [East], East window Copy heating 1,693 Btuh, cooling 2,196 Btuh Above Grade Wall, North, North wall dining room heating 449 Btuh, cooling 295 Btuh Window, [North], North window dining room heating 706 Btuh, cooling 390 Btuh Above Grade Wall, North, North wall bedroom heating 760 Btuh, cooling 499 Btuh Window, [North], North window bedroom heating 706 Btuh, cooling 390 Btuh Above Grade Wall, East, East wall kitchen heating 293 Btuh, cooling 108 Btuh Window, [East], East window kitchen heating 706 Btuh, cooling 915 Btuh Wood/Metal Door, East door kitchen heating 393 Btuh, cooling 254 Btuh Above Grade Wall, West, West wall kitchen heating 391 Btuh, cooling 144 Btuh Window, [West], West window kitchen heating 706 Btuh, cooling 915 Btuh Above Grade Wall, North, wall heating 1,080 Btuh, cooling 398 Btuh Ceiling, Ceiling heating 1,677 Btuh, cooling 1,922 Btuh Ceiling, Ceiling Copy heating 909 Btuh, cooling 1,041 Btuh Ceiling, kitchen ceiling heating 237 Btuh, cooling 271 Btuh Floor, floor heating 6,550 Btuh, cooling 2,612 Btuh Floor, kitchen floor heating 924 Btuh, cooling 368 Btuh Infiltration, heating 10,869 Btuh, cooling 3,829 Btuh Internal Gain, heating 0 Btuh, cooling 2,490 Btuh
    Project Load Summary ============================== ============ Walls : heating 9,975 Btuh, cooling 4,202 Btuh Glass : heating 12,701 Btuh, cooling 13,356 Btuh Doors : heating 786 Btuh, cooling 508 Btuh Ceilings : heating 2,822 Btuh, cooling 3,234 Btuh Floors : heating 7,474 Btuh, cooling 2,980 Btuh Infiltration : heating 10,869 Btuh, cooling 3,829 Btuh Internal Gains : heating 0 Btuh, cooling 2,490 Btuh ==============================
Size:  21.8 KBName:  uploadfromtaptalk1347283845932.jpg
Size:  38.3 KBName:  uploadfromtaptalk1347283869473.jpg
    Jun 2009
    Upstate SC
    I did a room load calc for the same job and it came out to 28000 BTU roughly. Its stored on the tablet at home.
    I did email the developer and they are looking at developing cloud storage to store project files.
