09-06-2012, 11:47 AM #1
- Sep 2012
- 8
Capacitor replaced, not mounted in hole--should I complain?
Hi guys. I have a Rheem 13PJA series heat pump, and the capacitor failed. Was replaced under the homeowner warranty. However the technician didn't have a capacitor that would fit in the same hole the failed capacitor came out of (the replacement is larger). So this it what the unit looks like now:
The replacement capacitor is somehow lodged in that compartment, and the base of the capacitor is of course no longer being cooled by the fan. I assume (hope?) he at least put some electrical tape on top of the capacitor.
I'm not a perfectionist and I'm OK with this as long as it works without shortening the lifespan of my heatpump or causing a danger to anyone. I'm a contractor myself (IT) and I understand sometimes things aren't always going to be pretty, but they don't have to be as long as they work.
Leave it alone or... ?
Thanks in advance for any help. Hopefully this is an easy question for the pros.
09-06-2012, 12:54 PM #2
Professional Member*
- Mar 2009
- Mount Holly, NC
- 1,616
leave it alone.
I HATE that design where the cap is shoved in a hole in the panel... often the old capacitor fails in such a way that it's impossible to remove.
if the system is running, and the cap is mounted in a way that it will not short or rub a refrigerant line, I'd be happy for the quick service.The TRUE highest cost system is the system not installed properly...
The three big summer hearththrobs...
Mel Gibson
Dwane Johnson
The A/C repairman
09-06-2012, 03:06 PM #3
- Sep 2012
- 8
Alright, thanks!
