Results 14 to 26 of 34
Thread: 1500 microns
    Atlanta GA area
    Quote Originally Posted by SBres22 View Post
    I value your opinion. Thank you. And WHY do I value your opinion and advice? Because you , sir, had the common courtesy to EXPLAIN it. The tech that was originally on the job was having issues with the system, which is why I got sent out as a fresh set of eyes and fresh mind. Because lets face it, once you start getting aggravated, you lose your mind a little. I understand that. It just seemed that EVERY bit of advice or question I brought up, I was basically belittled for.... Which is why it seems like I may have been a little bitter in a few of these posts. I 100% KNOW that I DO NOT KNOW everything, and never will. Which is what I think the other guy has a problem accepting about himself. I will be learning new things about this trade untill my mind no longer works right, and then I can learn all the basics all over!! LOL This other guy either A.) doesnt like me to begin with, or B.) doesn't like when the bossman thinks he needs help. I think B...... maayyybe A. too!
    Thank you gentlemen for your responses, and YES i will 100% let you know how this turns out!
    OK, now this is the part you may not like... however it is offered in the same spirit as before:
    It is not how much we know... it is how we relate it... Well in reality it is simply 'how we relate' to others. Just because someone else cannot relate, does not mean I cannot take up the slack and make lemons into lemonaide...
    It is the folks with communication and social skills who make it in life.
    Now 'get back to work'... LOL
    GA-HVAC-Tech
    Feb 2012
    Lynn, Mass
    ^no problems with the above post AT ALL. The way I was describing this on here I now look at and see I may not have been as clear, I believe the guy CAN get the job done most of the time. I have gotten into very few arguments with people in my life due to the fact that I listen well and I dont sweat the petty $h!t, I pet the sweaty stuff. lol. I was not speaking to him like I was explaining it on this board, I was asking him if he tried doing certain things and he was belittling me. I understand people have issues at home that may make them grumpy at times, but I always try to leave my issues at home when possible. I listened to my mom when she said "If you have nothing nice to say, then dont say nothing. I just don't wanna be shadowing a guy that doesnt explain why they are skipping the proper steps ESPECIALLY when they encounter problems that they cant figure out. I am COMPLETELY fine with him skipping certain things, but if they have me shadow you, EXPLAIN a little... I may not be coming across the right way via text on here, TRUST ME, I am not a hot headed guy. I wanna LEARN, not just be shown without explanation... If I am coming across wrong at all I completely apologize, I had a bit of a rough day getting yelled at for reasons that were beyond my control. I know people can fix things even though they have no personable skills...
    Thank you for your input 100%!!
    Jul 2012
    Western KY
    I agree with BS call. He is wrong you are rite. That doesn't nessisarily mean there is a leak or the system is contaminated or that it will not work fine. It means his procedures suck and you should not follow his example. Which you did not so good for you.
    Feb 2012
    Lynn, Mass
    Quote Originally Posted by ga-hvac-tech View Post
    btw, I said I ALWAYS appreciate constructive criticism. ALWAYS. You sir, have tact. other people may be better techs than you, but I'd rather have you on my team than some of them for that reason alone.
    Oct 2009
    Arizona
    Oops, I hit reply by mistake on my phone. How do you delete a post on tapatalk? LoL
    Mar 2009
    Mid-Mo
    From the sounds of it, I have my doubts that their first diagnosis was correct to start with. A good "tech" would have been able to prove non-condensibles and not stab at.
    The latter points are good points. I'd be a big upset too if the boss sent in the bail out crew when I was having problems with something then they proceeded to argue with me. Time will tell. Poor refrigeration practices will show up in the long run.
    Feb 2012
    Lynn, Mass
    Quote Originally Posted by Tommy knocker View Post
    Thats what I am getting at here! thank you for seeing it that way. I'm NOT saying I know what the problem is, I was saying "LETS FIGURE THIS EFFER OUT" All I was trying to do was BE POSITIVE one way or the other with what was wrong... No callback yet. For anybody keeping track. lol
    May 2011
    Eastern Washington State
    I agree with what the guys said before. In my opinion you always want to bring your system down to 500 microns..blank it off and let it sit. So many guys I know in this trade pull it to 500 and say *its good I got it down there* If you were to try and make It hold that it wont. If your really worried about it do a triple evacuation breaking with nitro then pump. Sounds to me like you have moisture in the system.
    Jul 2010
    Not to over simplify the matter, change your vac oil and check your hoses. Too much moisture in the oil, or a slightly leaky hose could be the problem.
    Jul 2011
    Lehigh Valley, PA
    Hey SBres22, I know that guy your are referring. I worked with him. I quit my job because I didn't want to deal with his non-sense. Have confidence, do what is right. Fix it right using fundamentally correct methods.
    In regards to losing some vacuum, for a 300 mi lost, did it continue to rise above 1550? From what I read, it jumped from 1200 to 1500 and hung tight? I;d be concerned the condition of my equipment, manifold, hoses, etc. I quit using my refrigerant manifold for vacuum work, went to a single hose and a vacuum stub style gauge. I also add a very small dab of vacuum grease on all of the schreader valve seals.
    NW AR
    Alot of times you can hear the reefer boiling out of the compressor oil. A piece of garden hose or even a screwdriver placed on the compressor and then to your ear will allow you to hear it. I warm the compressor and it usually speeds things up considerably.
    Most of time people who is insecure or belittle others is too make themself looks good.
    They don't want to look bad cause they don't know what they are doing.
    Whats exactly are you working on?
    Walk in? Reach in?
    Why do you think there's a leak?
    What happened to freezer
    Why did he feel the reason for this unit to go down was due to moisture ?
    We can talk about proper evac all day
    But if that's not what cause this unit Togo down then it will be down again.
    Feb 2012
    Lynn, Mass
    Now that i've thought about it, i dont believe it was a leak, i believe it was just air in system... the unit wasnt cooling properly, running constantly, then going off on HP. The store owner had another company come in and they diagnosed a leak and repaired it prior to our arrival. i think when they charged it, they forgot to purge their hoses. like i said before, i wasnt positive it was a leak. I just wanted to go through the proper steps. we havent gotten a call back yet, but that doesnt mean anything. the owner is the type that has VERY LITTLE patience with it not working and will call different companies every day! which makes stuff harder.It may be runnning just fine right now. I havent been back. And btw it was a TRUE reach in freezer.(I believe)
