Results 14 to 18 of 18
    Virginia
    I think 15 seer is the best bang for the buck also ussally have a few more upgrades like sound blankets and pressure switches ,you could put the units on the roof
    Go Trump
    Saint Joseph, MI
    Quote Originally Posted by catmanacman View Post
    Nah... just install some vertical wells and go geothermal. Then the compressors are indoors.
    Jun 2001
    No prices per forum rules.
    The Carrier Performance 15 Seer single stage is one of the quietest units on the market and Carrier's quietest unit. Nearly silent against typical outdoor background sound levels. I think York Affinity units are also super quiet. The Carrier compact side discharge is less efficient and noisier.
    Make sure you get your units sized correctly. IT would need to be a HUGE townhouse to require 9 tons of cooling... even in Houston or South Florida, we're talking 4000 sqft+ in most cases. Where do you live?
    To save some money, you can pair the 15 Seer Performance series AC with a Comfort Series Air handler with just a regular PSC motor. It will still get around 14 SEER and will be quiet.
    If the deck is open, you could fit the units up against the fence as long as you meet hte minimum clearnace on the other 3 sides. But 3' of width should be enough as long as the other 3 sides are open. The clearance requirements you can find by searching for (insert model number from Carrier website and add "data sheets" to a google search.
    Pick the most important factors in system selection, these 5 items tend to conflict with each other:
    High efficiency
    High capacity
    Small Physical Size
    Low Noise
    Low Cost
    Saint Joseph, MI
    You forgot high comfort level... if conflicts with 3 or 4 of them too.
    Sep 2012
    Mysteries, unravelled. Thanks to all for contributing!
