Results 14 to 22 of 22
09-05-2012, 07:40 PM #14
09-05-2012, 07:53 PM #15
say a wire going to a blower motor has a cut in it running thru a package unit. it blows a fuse every once in a while. you can not figure out why the fuse blows. you whip out your extech 380260 meter. you test the blower and it shows up good. you then test each wire that feeds the motor to ground. would the extech 380260 meter pickup the crack in the wire?
09-05-2012, 07:57 PM #16
Yes it should. But Id be curious to know if anyone else used a megger in that manner. I think you would be better off doing it the way your doing it. Physically check the wiring and ohm it out...
I have never condemned a motor that I didnt double check with my Fluke 28 II. I think they are more of a PM tool than anything else. Maybe Im Wrong but from what I read here and from Supco's website thats how I understood it.Gotta have the right tool for the job!
Where is all the stuff MADE IN THE USA?
"Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
09-05-2012, 08:01 PM #17
No return.
- Jul 2006
- NW burbs of Detroit
- 6,058
I don't claim to know everything but RSES membership would sure benefit a lot of guys on here.
09-05-2012, 08:36 PM #18
Professional Member*
- Apr 2011
- Coastal Maine
- 566
I tend to agree with HVAClover on this one, although not as stern in my objections. A megaohmmeter is a useful tool with hermetic compressors. It is just that, a tool, among many others. I have used them as a final check before condemning a compressor. Mine is older than most of you guys. I just bought one of the Exetech analogs as my old one is tired of being bounced around in the back of the truck.
But there is no single tool or meter that will do everything for you.
In my opinion, stick to the analog meters when reading MegaOhms.
Good Luck.
09-05-2012, 08:50 PM #19
if you were to use a regular meter while trying to find the crack in the wire that fed the blower motor you wouldn't have found it. this crack in the wire was found using a megohmer. the unit would run fine for a couple months and then blow a fuse. a new fuse would be put in and it would run for a few more months and pop a fuse. i have a supco m500 and it works but sucks at the same time
09-07-2012, 10:02 PM #20
Gravity- Common sense would dictate the answer to your question about a crack in the electrical wiring. Depending on where the crack is located in relation to the pinching action of the cabinet. A Carrier unit was doing exactly that with the condenser fan wires. If you megged the wires you would get a reading that would not indicate a problem. If you isolated the individual fans, there were 4 you would find a grounded lead supply power to the motor. The wire harness was pinched between 2 cabinet top sections and would only show a fault when the rest of the system was in operation.-GEO
Of all the things I have lost in my life, I miss my mind the most-GEO
09-09-2012, 03:47 AM #21If more government is the answer, then it's a really stupid question.
09-09-2012, 07:21 AM #22
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,219
http://fieldpiece.com/megometers/smg5
mine has served it's purpose through the years I've had it
