Results 1 to 11 of 11
    May 2002
    Carrier 30 HXC failed discharge check valves
    For your enjoyment...
    I don't like it ....at all....
    mikeacman
    May 2002
    Found this awhile back ,parts on backorder...
    mikeacman
    Ohio
    Ahhh yes... The tornado siren song of a failed check or solenoid valve.
    I have a Dunham Bush that has a liquid line solenoid stuck open, does it on every off cycle and still going strong after 5yrs. The compressor is starting to get a vibration from the screws running backwards I am assuming. The customer is very aware of the consequences but refuses to fix it.
    Lmao
    May 2002
    Quote Originally Posted by zw17 View Post
    I wonder how he will react when it scrambles.
    mikeacman
    Jul 2012
    Western KY
    Awsome.
    Not in Iran
    I have changed check valves on Trane screw compressors before, , remove the discharge line,. Remove valve and install new, not sure if the carrier is the same, ,. Really wasn't a difficult repair,. But like I said not sure abot the carrier,.
    Sep 2012
    Auckland , South Pacific.
    Watched an open drive Stal screw do the same thing, overspeed drive motor backwards so fast the cooling fan disintergated and destroyed a 185 Kw motor, very expensive repair.
    East of big city prices.
    Quote Originally Posted by milkyway View Post
    It's not too bad it's when you get in there and see how it made and you say how can it fail.
    Not in Iran
    Dallas, haven't seen one but check this out,
    http://hvac-talk.com/vbb/showthread....AA+check+valve
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Greenville SC
    I've changed out a couple of those. The funny thing is I never see anything wrong with the devective valve. But when I change it out, no more back flow. The good news is they are easy to change.
