Results 1 to 11 of 11
09-04-2012, 06:02 PM #1
- May 2002
- evansville indiana
- 892
Carrier 30 HXC failed discharge check valves
For your enjoyment...
I don't like it ....at all....mikeacman
09-04-2012, 07:50 PM #2
- May 2002
- 892
Found this awhile back ,parts on backorder...
mikeacman
09-04-2012, 08:18 PM #3
Ahhh yes... The tornado siren song of a failed check or solenoid valve.
I have a Dunham Bush that has a liquid line solenoid stuck open, does it on every off cycle and still going strong after 5yrs. The compressor is starting to get a vibration from the screws running backwards I am assuming. The customer is very aware of the consequences but refuses to fix it.UA LU189
10mm, because it's better than .45acp
09-04-2012, 08:19 PM #4
Lmao
09-04-2012, 10:44 PM #5
- May 2002
- 892
09-05-2012, 08:12 AM #6
Awsome.
09-06-2012, 10:19 PM #7
I have changed check valves on Trane screw compressors before, , remove the discharge line,. Remove valve and install new, not sure if the carrier is the same, ,. Really wasn't a difficult repair,. But like I said not sure abot the carrier,.
09-06-2012, 10:55 PM #8
New Guest
- Sep 2012
- Auckland , South Pacific.
- 3
Watched an open drive Stal screw do the same thing, overspeed drive motor backwards so fast the cooling fan disintergated and destroyed a 185 Kw motor, very expensive repair.
09-06-2012, 11:42 PM #9
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,506
09-07-2012, 12:20 AM #10
Dallas, haven't seen one but check this out,
http://hvac-talk.com/vbb/showthread....AA+check+valveno signature
blast'em man blast'em
!!!KILL THE TERRORIST!!!
09-12-2012, 07:59 PM #11
- Aug 2002
- Greenville SC
- 398
I've changed out a couple of those. The funny thing is I never see anything wrong with the devective valve. But when I change it out, no more back flow. The good news is they are easy to change.
