Results 14 to 25 of 25
    Jul 2012
    Quote Originally Posted by vstech View Post
    not a valid assumption. two different values, between the fan and the compressor. and the fan is pretty much a standard, the compressor has to be exact.
    I'll make sure to have the tech check the capacitor. Thanks for the help all
    Jul 2012
    Update - the tech found that the compressor was overamped, and recommended replacing the compressor. Couple hours after he left, the breaker tripped again and won't reset. So, w/o A/C upstairs for now, waiting to contact home warranty to see how much this will cost.
    Quote Originally Posted by Johnnyma45 View Post
    That doesn't sound like a valid diagnosis to me.
    To say that a compressor is 'overamped' without identifying a cause for that is not making a complete diagnosis.
    Now, that the breaker will not reset is bad news, IMO.
    X2
    Jul 2012
    So, taking the fact that, if it is overamped, what typically could cause that? I attributed it to the age of the unit (and the fact that I replaced the downstairs unit's compressor earlier this year), but I am not an expert.
    I tried the breaker again tonight after a few hours off, and it seems to be working right now...but it probably won't last. I probably shouldn't touch it anymore.
    Dirty cond coil, weak or stopping condenser fan
    I just found almost this exact condition on a large rooftop unit.
    Condenser was very dirty causing high amperage and blowing 80 amp fuses.
    Got those coils cleaned and it has been running like a champ all summer long.
    The fact that your unit is running right now and providing cold air means that there is nothing wrong with the compressor. Don't pay or a perfectly good compressor to be replaced.
    Aug 2011
    hard start
    The AOP forums/Ask Our Pro's forums, are restricted to only Pro members that have been vetted by the AOPC can post advise, questions or commentary in a thread created by someone else. You need to apply for your vetting/* if you wish to participate in threads in the AOP forums. Please apply to the AOPC today, thank you.
    jose_nina, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    S.E. Pa
    Cool check the wiring
    Didn't see where anyone advised to have the wiring inspected. If the wire to that breaker is loose, it can cause high amp draw which can either cause the breaker to trip or arc and fry. In my attachments, note the top wire was only slightly darkened. Yet the screw was loose--it should be tight. Now note the damage where the breaker failed and arced. I found it when I found indoor rated cable used on the roof condenser's disconnect and the outer jacket eroded exposing the inner wires and went to replace it. This breaker would not kill the power to the unit. Had to kill the main panel to replace the breaker and cable to the disconnect.
    Note: handling line voltage can kill you! Hire a pro HVAC technician or electrician only!
    Quote Originally Posted by lynnsacandheating123 View Post
    It was spam
    Many Thanks.
    what does this have to do with the post?
    school. That was spam, I edited the quote of it from your post.
