Results 1 to 2 of 2
    Aug 2010
    Northern Cali
    I have a question about a unit installed with honeywell zone. Unit is shutting off due to dats causing cool light to blink and compressor to cycle.
    The system has bypass damper, but with no weight . as far as I know it has always been like that and worked fine. I haven't spent a lot of time on this issue yet. But I thought I would post and get some ideas.
    When I was on sight I noticed that the bypass to touch was ice cold. I disconnected dats temporarily to allow unit to run with out cycling off. but I am worried about evap icing up. Maybe dats is bad I don't know Another thing when I opened panel on furnace alot of rat poop i meen a lot. I am worried that it is possible that maybe the rats ate thru ductwork. Going back to add weight to bypass. But any ideas would help thank you
    Jul 2012
    check the charge, set the bypass to factory specs.
