    Carrier Infinity
    We are renting a house that has 2 Infinity systems.
    I have noticed that the AC will run when it seems like it shouldn't.
    Here's what I I mean.
    The ACTUAL Temp reads: 73. I believe this is the indoor temp.
    The OUTSIDE Temp reads: 77.
    COOL is set to 76.
    Why is the AC running when the ACTUAL temp is less than the COOL temp?
    Does the OUTSIDE Temp somehow factor into the equation?
    The house has 2 systems, and I've seen this on both.
    Quote Originally Posted by dad004 View Post
    COOL is set to 76.
    Check your d-humidification settings and the Rh in the space, what may be happening is it is reading the humidity in the space and giving a command to dehumidify
    Oct 2010
    Anderson SC
    You may be confusing the actual temp with the set point temp
