Thread: Payne heat pump
    Sep 2012
    Payne heat pump
    I have a payne HEAT PUMP model# PH10JA048-B. It stopped working last night. I noticed the breaker was tripped. When i went to turn it back on it wouldn't allow me and kept tripping. I checked the disconnect and the whip to the heat pump and it all checked out fine; when i reconnected the whip back to the heat pump it tripped. What could be the problem that would trip the power to the unit? It was installed 8 years ago and the only thing i have had to replace since install has been the capacitor.
    Oct 2010
    Direct short somewhere
    Sep 2012
    Quote Originally Posted by jtrammel View Post
    a short in the unit? where would it most likely be, in the relay? there is also a mother board, could that be the issue? is this common with this type of heat pump from payne?
    there's no way to see that unit from here; so, go ahead and call your service contractor to come out.
    Quote Originally Posted by skafiore View Post
    I don't think that brand matters so much.
