Results 1 to 4 of 4
    Sep 2012
    Trane EYKD Supply Air Temp Sensor (UK)
    Hello
    I have just taken over the HVAC of an Asda store (Walmart) in the UK,
    It has 6 Roof Trane Units fitted, EYKD250, they are the first and only Trane units I have come across,
    they are connected to and controlled by a BAS BMS system with Tracer Summit interface,
    and 1 of the units supply air temperature is showing about 10 deg c lower than the actual temp,
    with the manuals I can find there is not enough info to identify the supply air temp sensor or the wiring terminals,
    the manuals only show installation, spec and options.
    I cannot find a wiring diagram at all. Can anyone help with sensor location, terminal identification, wiring diagram and possibly what ohms I should get across the sensor?
    Any help is much appreciated.
    Nov 2012
    Thumbs up Do you want some assistance from Trane?
    DUFLA
    it will be wherever the installing contractor put it, in short, you're gonna have to go hunting for it.
