Results 1 to 10 of 10
    Sep 2012
    Confused Thermostat is off and unit cycles on
    I have a Goodman Heat/AC unit and when the thermostat is off (both fan and Heat/AC switches), the unit will cycle on for a few minute. The air blowing out of the vents is room temperature. It does it mostly a night when the outside and inside temps are most different. Any ideas other that ghosts? Thanks.
    Jan 2012
    Broomall, PA
    What type of thermostat do you have? Can you take a pic of the screen when this occurs? Also does this cycling occur after a call for heat? It's possible there's a thermostat/wiring issue, but need some more info
    Sep 2012
    Honeywell Thermostat
    Quote Originally Posted by STEVEusaPA View Post
    It is a Honeywell seven day programmable thermostat. This is happening now, so no call for heat. The set up has is 10 years old, so it is not a wiring issue. I noticed this behavior around six months ago. I have disconnected the thermostat to see if it resolves the issue. Maybe a faulty thermostat (?). There is no change to the screen when this happens.
    Jun 2001
    Are you sure you don't have an aircycler hooked to your system?
    Oct 2010
    Quote Originally Posted by 54regcab View Post
    The fan relay may be sticking
    Jun 2001
    Quote Originally Posted by jtrammel View Post
    Could be, but all the sticking relays I've seen will just keep the blower going after a cycle has completed. It's odd that the blower just starts by itself.
    Oct 2010
    I agree but something has to be going on, could be a bad circuit board or corroded batteries in tstat or just a bad tstat
    Oct 2010
    Quote Originally Posted by edslee View Post
    Have you ever changed the batteries in tstat?
    SW Wisconsin
    Well, the older heating furnace setups could & often did do that due to the fan cycling thermostat switch being in the plenum area & directly wired to the 120 volt power.
    That way it is totally independent of the thermostat & would recycle especially after a heating cycle; the room thermostat could be removed & the blower would still be able to recycle.
    Though of course, I don't know how your system is wired or sensors used...
    No, it's not ghosts...
    Is the unit in the attic.
