Results 1 to 10 of 10
    Jun 2001
    Moore, Oklahoma
    14 SEER and higher units under 3 tons
    How many A/C systems do you sell that are 14 SEER or higher and less than 3 tons? I never see them installed in our area. The high SEER units I find are normally 4 or 5 tons, the 3 and 3.5 ton high SEER units are rare.
    Dec 2010
    When I sold equipment, it was almost always 14+ SEER mainly because of the rebates from the utility company. The warmer the weather, of course, the more important the higher SEER.
    Payback on high SEER is faster on big units. In our area, you might save $10-15 a year in a 2 ton going 14 over 13 which can translate to a non-existent ROI. If a utility rebate covers most of the cost of the upgrade, might be worth doing. Otherwise, not.
    Jun 2001
    Moore, Oklahoma
    I've seen a LOT of high SEER unit oversizing. Somehow people think they can have it all by oversizing the A/C to keep cool well beyond design conditions and the high SEER rating will save them on their power bill. Then people are wondering why their power bills haven't dropped...
    Dec 2010
    What I found was that most contractors size the new A/C the same as the old A/C without taking the time to see if it's the correct size.
    It's much more critical to properly size the newer, higher efficiency units.
    Jun 2001
    Moore, Oklahoma
    Quote Originally Posted by George2 View Post
    That's what I was thinking. Ductwork is normally marginal for their old system, but may be plenty for a smaller system.
    Dec 2011
    San Antonio, TX
    Code in my area is minimum 14 seer. I mostly due RNC so duct work is designed accordingly.
    Sent from my ADR6350 using Tapatalk 2
    Jun 2001
    Moore, Oklahoma
    Quote Originally Posted by dsprice View Post
    Interesting code requires a minimum SEER but there is no limit on how many tons per sq ft can be used. If they were really interesting in reducing peak power demand, forcing smaller units would be more effective than increasing SEER IMHO.
    Dec 2010
    Now you're opening a whole new can of worms........ductwork is the delivery system, no different (really) than vains and arteries in a body.
    The problem is that the equipment is too forgiving. I'm sure we've all seen systems that shouldn't be working but the owner says, "It works fine."
    Jun 2001
    Moore, Oklahoma
    Sure an oversized unit keeps the house cool, it's just not very efficient when trying to cram 4 tons of A/C down 2 tons of ductwork.
