Results 1 to 13 of 14
    Sep 2012
    help with service call
    I have ac with gas furnace system that will run for thirty seconds then everything will cut off including thermostat in ac. It will come on & run for a couple seconds & cycle off & on. runs fine in heat. changed transformer but same thing. will pressure switch make thermostat go blank?
    Southeastern Pa
    In order to give you the response you expect, we need two things:
    1) you need to get your post count up to 15 and apply for the free Pro membership, and have it approved.
    2) you need to ask this in Pro Residential, and not in an open forum.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    NC
    Quote Originally Posted by timebuilder View Post
    That is an excellent post TB.
    Feb 2012
    Toronto Canada
    Didn't know you had 2 post. TB already sstated the rules in this Thread sure the other will be deleted.
    Sep 2012
    What am I supposed to post about if I can't post my question to get my post count to 15?
    Southeastern Pa
    I would say that you could share some knowledge and experiences in the Tech to Tech forums, which are open to new members, and in that way you can show what you are about while not walking a new member through what could be a DIY procedure. In this way, you give the membership committee something to review along with the other info.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Oct 2011
    between here and over there
    Sorry this is not a DYI site. Please consider calling your local Professional Contractor, or follow the site rules.
    Southeastern Pa
    OP,
    as you can see, it is nearly impossible to tell a DIY post from a post by a new member in the trade, unless the info given in the post suggests otherwise.
    Still, the open forums are searched and indexed by the search engines, and we don't want DIY posts indexed and available to the general public.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Sep 2012
    Homeowners don't know what pressure switches are? I'm no master tech but I know more than most. Just admit you don't know.
    Feb 2012
    Toronto Canada
    I don't know everything about this trade OP I am learning something new everyday where did you go for your training for your HVAC career?
    May 2012
    Upper Michigan
    I bet a homeowner would know what a pressure switch is, if the switch opens I guess it would kill everything In string, of for some reason the tstat was in the safety string then that could be true lol.
    Sep 2012
    I've been in industry for 10 years. All training I've done was in field or at a distributors. I have mainly worked for a distributor but have 3 years field experience.
    Homeowners don't know what a pressure switch is unless you just explained it them & then still...
    May 2012
    Upper Michigan
    Quote Originally Posted by brogers1 View Post
    Some don't know what hole to wipe when they sh!t but others know there sh!t
