Results 1 to 13 of 22
Thread: Trane CH530 Screen lockup
09-01-2012, 10:48 PM #1
- Jul 2012
- TX
- 51
Hello all,
I have recently ran across a Trane RTAC255 with the CH530 Dynaview display. The initial call was for a display lockup. When running for a while the display will "freeze" but when online with techview 14.0 you can see the processor actually running. I change the Dynaview and loaded the appropriate software and watched it run for an hour or so while I CHANGED A FLOW SWITCH. A week later the problem has returned on the new module. All devices appear to be properly bound in binding view, so has anybody ran into this one before?
09-02-2012, 08:31 PM #2
I have had the touch screen fail and had to replace but havnt seen one lock up myself. Is it locking up in a menu screen or will it just not let you punch in access code?
09-03-2012, 12:24 AM #3
- Oct 2010
- GREECE
- 18
Hi,
Try to download a previous version of RTAC software.
Regards,
CV
09-03-2012, 10:36 AM #4
Heres a better idea .
Load a different type of chiller software into the dynaview , boot it up and you will get a configuration error and all kinds of goofy alarms . then reload the correct RTAC software and you should be good . Reloading old software will not eliminate the bug in the software , loading completely different (incorrect) software will, it erases all the memory and gives you a fresh start .You bend em" I"ll mend em" !!!!!!!
Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
09-03-2012, 01:21 PM #5
09-03-2012, 07:15 PM #6
- Jul 2012
- TX
- 51
Thanks for the info. Sounds logical to me. I'll give it a shot
09-03-2012, 07:36 PM #7
i do not know if i should post it here but there is a trane secret to reboot the dynaview!
then of course you will have to do a little data entry!!!!!!!!!!!!!!
or should i say menu selecting?I WILL SELL WORK,GENERATE BUSINESS, GO GET NEW CUSTOMERS!
YOU SHUT THE HELL UP AND QUIT RUNNING YOUR MOUTH!
09-03-2012, 08:14 PM #8
09-03-2012, 08:19 PM #9
09-03-2012, 08:23 PM #10
i PMd it to you MW!!!!!!!!
09-03-2012, 11:10 PM #11
Professional Member*
- Jul 2007
- The Hot South
- 869
09-03-2012, 11:51 PM #12
I did not think it to be a good idea!!!
09-04-2012, 12:52 PM #13
- Jul 2012
- TX
- 51
Just got pro membership. Can you post this in the pro forum?
