Results 1 to 9 of 9
Thread: Burn out!
    Aug 2012
    FL
    Burn out!
Size:  49.7 KB Name:  IMG_3562.jpg
Size:  57.0 KB Name:  IMG_3563.jpg
    Jul 2009
    In a mechanical room....
    Did you Meg it to be sure
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    Aug 2012
    FL
    Yeap, this motor is gone, I installed a new remanufactured Trane motor, is up and running. It was a task moving around a almost 4,000 lbs. Motor.
    Nice job! It's quite a task changing a motor on one of those, but at least it was a CVHF, and not a CVHE!
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    Aug 2012
    FL
    I agree. On a CVHE there is a couple more steps, the shaft is different.
    Sep 2012
    NW Louisiana
    What is that 50-75hp?
    Quote Originally Posted by nsula_country View Post
    It's more likely to be in the 500-750 HP range
    Sep 2012
    NW Louisiana
    Quote Originally Posted by Tech Rob View Post
    Hard to tell in the pictures, nothing to compare it too. I should have picked up on the 4000 LBS part, LOL. I'm guessing that goes on a chiller?
    CT
    CT
    Yes, a Trane centrifugal. The motors can weigh anywhere from 2600 lbs. to 4400 lbs. Requires a complete compressor disassembly to remove the motor.
