Thread: RTAA
    RTAA
    Has anyone had a problem with a rtaa100 when in ice making , have a unit when in ice making , every 3 or 4 days temp will drop to 20 deg and cut unit off on ice making complete, just had control tech to set up trends on pumps, valves, just wondering if anyone has had a problem like this. I have allot more details , but just wondering if anyone has had an issue like this, [of course this happens a night when no one is there]
    Jun 2006
    midwest
    i suggest testing the evap temp sensors, both in and out. Replace as a pair.
    Quote Originally Posted by gary254 View Post
    perhaps the setpoint is set to 20? if you want good answers, you have to give good info.
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    Apr 2012
    Paper Street Soap Company
    Factory default cut out on a RTAA for low refrigerant temp is 22 degrees. I assume you're running glycol.
    Perhaps that machine needs to be reconfigured.
