Results 1 to 8 of 8
    Why Zero Out A Manifold Gauge?
    In a RSES tech tip I read Quoted directly from Ritchie Engineering about analog gauges "Why Zero Out A Manifold Gauge?"
    It said a gauge can get off 0 due to change in altitude or barometric pressure. It is important that you set it back to 0 before charging.
    FWIW A bourdon tube analog gauge is not affected by by altitude or barometric pressure. If your open to ATM gauge is reading 0 at sea level and you take it up to 10,000 ft open to ATM it will still read 0. Additionally if you are using the PT chart printed on the gauge face for charging or troubleshooting at altitude with the gauge open to ATM you should adjust the needle off 0 and set it to the equivalent psia of the environment you are in.
    You are correct, but I quit using analogue refrigerant gauges years ago, don't even own any anymore, and I try not to think about them much.
    Well the RSES cover story that I grabbed the incorrect tip from is "Not all digital manifolds are created equal"
    Guess one of their major advertisers got PI55ED from a previous article bashing their digital gauge and RSES let another one fly LOL
    Rapid City, SD
    There's some threads around here that suggest calibrating the gauges in the middle of their operating range. Get a bottle of refrigerant that's at a stead temp, hook your gauges up to it, find the temp of the freezone, and adjust it so it reads correctly there. Ignore what it's on when there's no pressure.
    Makes sense to me, I'd rather have it accurate in mid swing (much closer to where I generally need the measurement taken) than 0.
    I've done it to my gauges a couple times, but I'll admit, I don't touch my gauges much at all. It is admittedly easier to just set them at 0 when they get way off...
    Nov 2011
    East Side
    yes you have to calibrate an analogue gauge at the top center of its' chart (the most accurate part)......none of my analogues read zero after being calibrated.
    Quote Originally Posted by 71CHOPPS View Post
    Bummer
    Was at a supply house today and none of the analog gauges read zero LOL
    Nov 2011
    East Side
    Bummer
    Not really....I expect it. It's only a problem doing refrigeration work....haven't done any of that for a few months, so no biggie right now......if i get into it again, yes, it is a bummer!!LOL!!
