Results 1 to 8 of 8
08-30-2012, 12:23 AM #1
- Aug 2012
- 78
Is there such a thing as Plastic Duct work?
In talking to a contractor they gave me three quotes, one for flex tube, next most expensive was fiberglass duct board, and most expensive was sheet metal.
I thought for sure there would be some cheap chemical weld plastic that everyone was using now a days.
Obviously plastic melts in the heat, but there are a lot of plastics that can take the heat. Is there any reason there isn't a plastic duct work system available?
08-30-2012, 08:11 AM #2
- Jun 2001
- Moore, Oklahoma
- 2,674
Problem with plastic is it needs to be insulated just like metal duct. It costs more than metal duct and isn't a stock item at many supply houses.
08-30-2012, 10:09 AM #3
Professional Member*
- Oct 2011
- NJ
- 120
There is a CFC free Phenolic foam duct board called "KoolDuct." It is is lighter than metal duct, is foil faced, has insulated/lined acoustic and R-value characteristics, leaks less than metal ductwork sealed to SMACNA Class 6. Better R value than similar thickness of fiberglass ductboard.
Problem is it can only be installed by a certified installer, and it costs more for the materials than metal, but the installation is supposed to be cheaper.
08-30-2012, 10:15 AM #4
I think the big problem with plastics are the smoke and fire ratings.
Sent from my SCH-I500 using Tapatalk 2
08-30-2012, 10:34 AM #5
- Oct 2011
- NJ
- 120
Phenolic foam has excellent fire resistance and flame spread ratings and low levels of toxic fume emissions in a fire. It's used as insulation in walls, roof cavities, as sarking boards, and under floors.
08-30-2012, 01:46 PM #6
- Oct 2006
- The Beach
- 468
Plastic is avilable but every supply does not have it. All the material will have to be ordered. It does make a good job and is easy to insulate.
Blue Fox
09-03-2012, 09:13 PM #7
- Jun 2010
- Philadelphia PA
- 2,139
You have your quotes, so the decision is clear, the FG Trunk with branches ( flex if accessiable andr "hard pipe" insulated if not accessible) and by the way the KoolDuct is very specialized and more expensive than res sheet metal!
I would keep the return short and sweet with transfer (jump) ducts for room returns
Good luckYou have got to learn from other people's mistakes! Because God knows you don't live long enough to make them all yourself !!!!!!!!
09-04-2012, 10:53 AM #8
- Oct 2011
- NJ
- 120
